If I execute the statements one at a time they work. As a group they fail. I'm running MySQL V5.0.92.
Doug
It didn't work either but I found the solution.
Tables in my database have extension zen_
I added that prefix to table name in your SQL file, it was configuration in my case it became zen_configuration
It is fine it works, very nice
hi,
all installed and very good, just one problem if i add a featured item from the
Product ID to be Manually Added as a Featured
the featured status is allways disabled, which cant be changed. if i add the product in the normal way all is fine
any help appreciated
bryan
I'm taking a look at that right now. You likely did install it properly. It's a pretty straightforward install. I'll update you all when I figure out what i did wrong.
here is files i updated to get this module to work properly, when you click on the status button it works and auto start stop feature now works,
hope this helps everyone,
bryan
Thank you Bryan you saved me a lot of time trying to fix it. I am just trying to move over some of the edits to an override file and will be uploading an update to zen cart shortly. I'll respond to your other emails about the other updates/changes you made tot he mod as well. Just been swamped with work as usual.
Hi Ryan and thanks for sharing this mod.
Do you have an uninstall sql?
Bryan there helped by fixing some issue with the mod. I actually created it.
I'll be releasing an update soon when I have a chance to include some more edits Bryan had made.
-Kris
Hello
I need some help my site is www.odin2828.com i install this mod, no error show but i cant not display the featured boxes in the main page.
Did you follow all the directions in the read me?
