* @package admin
* @copyright Copyright 2003-2009 Zen Cart Development Team
* @version $Id: configuration.php 14193 2009-08-18 04:15:13Z drbyte $
$action = (isset($_GET['action']) ? $_GET['action'] : '');
if (zen_not_null($action)) {
switch ($action) {
case 'save':
// demo active test
if (zen_admin_demo()) {
$_GET['action']= '';
$messageStack->add_session(ERROR_ADMIN_DEMO, 'caution');
zen_redirect(zen_href_link(FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $cID));
$configuration_value = zen_db_prepare_input($_POST['configuration_value']);
$cID = zen_db_prepare_input($_GET['cID']);
$db->Execute("update " . TABLE_CONFIGURATION . "
set configuration_value = '" . zen_db_input($configuration_value) . "',
last_modified = now() where configuration_id = '" . (int)$cID . "'");
$configuration_query = 'select configuration_key as cfgkey, configuration_value as cfgvalue
from ' . TABLE_CONFIGURATION;
$configuration = $db->Execute($configuration_query);
// set the WARN_BEFORE_DOWN_FOR_MAINTENANCE to false if DOWN_FOR_MAINTENANCE = true
if ( (WARN_BEFORE_DOWN_FOR_MAINTENANCE == 'true') && (DOWN_FOR_MAINTENANCE == 'true') ) {
set configuration_value = 'false', last_modified = '" . NOW . "'
where configuration_key = 'WARN_BEFORE_DOWN_FOR_MAINTENANCE'"); }
$gID = (isset($_GET['gID'])) ? $_GET['gID'] : 1;
$_GET['gID'] = $gID;
$cfg_group = $db->Execute("select configuration_group_title
from " . TABLE_CONFIGURATION_GROUP . "
where configuration_group_id = '" . (int)$gID . "'");
if ($gID == 7) {
$shipping_errors = '';
if (zen_get_configuration_key_value('SHIPPING_ORIGIN_ZIP') == 'NONE' or zen_get_configuration_key_value('SHIPPING_ORIGIN_ZIP') == '') {
$shipping_errors .= '<br />' . ERROR_SHIPPING_ORIGIN_ZIP;
if (zen_get_configuration_key_value('ORDER_WEIGHT_ZERO_STATUS') == '1' and !defined('MODULE_SHIPPING_FREESHIPPER_STATUS')) {
$shipping_errors .= '<br />' . ERROR_ORDER_WEIGHT_ZERO_STATUS;
if (defined('MODULE_SHIPPING_USPS_STATUS') and (MODULE_SHIPPING_USPS_USERID=='NONE' or MODULE_SHIPPING_USPS_SERVER == 'test')) {
$shipping_errors .= '<br />' . ERROR_USPS_STATUS;
if ($shipping_errors != '') {
$messageStack->add(ERROR_SHIPPING_CONFIGURATION . $shipping_errors, 'caution');
<!doctype html public "-//W3C//DTD HTML 4.01 Transitional//EN">
<html <?php echo HTML_PARAMS; ?>>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET; ?>">
<title><?php echo TITLE; ?></title>
<link rel="stylesheet" type="text/css" href="includes/stylesheet.css">
<link rel="stylesheet" type="text/css" href="includes/cssjsmenuhover.css" media="all" id="hoverJS">
<script language="javascript" src="includes/menu.js"></script>
<script language="javascript" src="includes/general.js"></script>
function init()
cssjsmenu('navbar');
if (document.getElementById)
var kill = document.getElementById('hoverJS');
kill.disabled = true;
</script>
</head>
<body marginwidth="0" marginheight="0" topmargin="0" bottommargin="0" leftmargin="0" rightmargin="0" bgcolor="#FFFFFF" onLoad="init()">
<!-- header //-->
<?php require(DIR_WS_INCLUDES . 'header.php'); ?>
<!-- header_eof //-->
<!-- body //-->
<table border="0" width="100%" cellspacing="2" cellpadding="2">
<tr>
<!-- body_text //-->
<td width="100%" valign="top"><table border="0" width="100%" cellspacing="0" cellpadding="2">
<tr>
<td><table border="0" width="100%" cellspacing="0" cellpadding="0">
<tr>
<td class="pageHeading"><?php echo $cfg_group->fields['configuration_group_title']; ?></td>
<td class="pageHeading" align="right"><?php echo zen_draw_separator('pixel_trans.gif', HEADING_IMAGE_WIDTH, HEADING_IMAGE_HEIGHT); ?></td>
</tr>
</table></td>
</tr>
<tr>
<tr>
<td valign="top"><table border="0" width="100%" cellspacing="0" cellpadding="2">
<tr class="dataTableHeadingRow">
<td class="dataTableHeadingContent" width="55%"><?php echo TABLE_HEADING_CONFIGURATION_TITLE; ?></td>
<td class="dataTableHeadingContent"><?php echo TABLE_HEADING_CONFIGURATION_VALUE; ?></td>
<td class="dataTableHeadingContent" align="right"><?php echo TABLE_HEADING_ACTION; ?> </td>
</tr>
$configuration = $db->Execute("select configuration_id, configuration_title, configuration_value, configuration_key,
use_function from " . TABLE_CONFIGURATION . "
order by sort_order");
while (!$configuration->EOF) {
if (zen_not_null($configuration->fields['use_function'])) {
$use_function = $configuration->fields['use_function'];
if (preg_match('/->/', $use_function)) {
$class_method = explode('->', $use_function);
if (!is_object(${$class_method[0]})) {
include(DIR_WS_CLASSES . $class_method[0] . '.php');
${$class_method[0]} = new $class_method[0]();
$cfgValue = zen_call_function($class_method[1], $configuration->fields['configuration_value'], ${$class_method[0]});
$cfgValue = zen_call_function($use_function, $configuration->fields['configuration_value']);
$cfgValue = $configuration->fields['configuration_value'];
if ((!isset($_GET['cID']) || (isset($_GET['cID']) && ($_GET['cID'] == $configuration->fields['configuration_id']))) && !isset($cInfo) && (substr($action, 0, 3) != 'new')) {
$cfg_extra = $db->Execute("select configuration_key, configuration_description, date_added,
last_modified, use_function, set_function
where configuration_id = '" . (int)$configuration->fields['configuration_id'] . "'");
$cInfo_array = array_merge($configuration->fields, $cfg_extra->fields);
$cInfo = new objectInfo($cInfo_array);
if ( (isset($cInfo) && is_object($cInfo)) && ($configuration->fields['configuration_id'] == $cInfo->configuration_id) ) {
echo ' <tr id="defaultSelected" class="dataTableRowSelected" onmouseover="rowOverEffect(this)" onmouseout="rowOutEffect(this)" onclick="document.location.href=\'' . zen_href_link(FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $cInfo->configuration_id . '&action=edit') . '\'">' . "\n";
echo ' <tr class="dataTableRow" onmouseover="rowOverEffect(this)" onmouseout="rowOutEffect(this)" onclick="document.location.href=\'' . zen_href_link(FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $configuration->fields['configuration_id'] . '&action=edit') . '\'">' . "\n";
<td class="dataTableContent"><?php echo $configuration->fields['configuration_title']; ?></td>
<td class="dataTableContent"><?php echo htmlspecialchars($cfgValue); ?></td>
<td class="dataTableContent" align="right"><?php if ( (isset($cInfo) && is_object($cInfo)) && ($configuration->fields['configuration_id'] == $cInfo->configuration_id) ) { echo zen_image(DIR_WS_IMAGES . 'icon_arrow_right.gif', ''); } else { echo '<a href="' . zen_href_link(FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $configuration->fields['configuration_id']) . '" name="link_' . $configuration->fields['configuration_key'] . '">' . zen_image(DIR_WS_IMAGES . 'icon_info.gif', IMAGE_ICON_INFO) . '</a>'; } ?> </td>
</tr>
$configuration->MoveNext();
</table></td>
$heading = array();
$contents = array();
switch ($action) {
case 'edit':
$heading[] = array('text' => '<b>' . $cInfo->configuration_title . '</b>');
if ($cInfo->set_function) {
eval('$value_field = ' . $cInfo->set_function . '"' . htmlspecialchars($cInfo->configuration_value) . '");');
$value_field = zen_draw_input_field('configuration_value', $cInfo->configuration_value, 'size="60"');
$contents = array('form' => zen_draw_form('configuration', FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $cInfo->configuration_id . '&action=save'));
if (ADMIN_CONFIGURATION_KEY_ON == 1) {
$contents[] = array('text' => '<strong>Key: ' . $cInfo->configuration_key . '</strong><br />');
$contents[] = array('text' => TEXT_INFO_EDIT_INTRO);
$contents[] = array('text' => '<br><b>' . $cInfo->configuration_title . '</b><br>' . $cInfo->configuration_description . '<br>' . $value_field);
$contents[] = array('align' => 'center', 'text' => '<br>' . zen_image_submit('button_update.gif', IMAGE_UPDATE, 'name="submit' . $cInfo->configuration_key . '"') . ' <a href="' . zen_href_link(FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $cInfo->configuration_id) . '">' . zen_image_button('button_cancel.gif', IMAGE_CANCEL) . '</a>');
default:
if (isset($cInfo) && is_object($cInfo)) {
$contents[] = array('align' => 'center', 'text' => '<a href="' . zen_href_link(FILENAME_CONFIGURATION, 'gID=' . $_GET['gID'] . '&cID=' . $cInfo->configuration_id . '&action=edit') . '">' . zen_image_button('button_edit.gif', IMAGE_EDIT) . '</a>');
$contents[] = array('text' => '<br>' . $cInfo->configuration_description);
$contents[] = array('text' => '<br>' . TEXT_INFO_DATE_ADDED . ' ' . zen_date_short($cInfo->date_added));
if (zen_not_null($cInfo->last_modified)) $contents[] = array('text' => TEXT_INFO_LAST_MODIFIED . ' ' . zen_date_short($cInfo->last_modified));
if ( (zen_not_null($heading)) && (zen_not_null($contents)) ) {
echo ' <td width="25%" valign="top">' . "\n";
$box = new box;
echo $box->infoBox($heading, $contents);
echo ' </td>' . "\n";
</tr>
</table></td>
</tr>
</table></td>
<!-- body_text_eof //-->
</tr>
</table>
<!-- body_eof //-->
<!-- footer //-->
<?php require(DIR_WS_INCLUDES . 'footer.php'); ?>
<!-- footer_eof //-->
<br>
</body>
</html>
<?php require(DIR_WS_INCLUDES . 'application_bottom.php'); ?>
