Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 70
    Default Re: Need help with attributes please
    Is this site run in the root directory of the site or in a subdirectory such as /shop or /store or /catalog ...
    If so, you need to add that to that changes you have made ...
    I am not sure why you are making those changes, but if you plan to use them, they do need to be specific ...
    I was following this tutorial in order to protect the download files which are essentially our product from being downloaded with out permission.
    https://www.zen-cart.com/tutorials/i...hp?article=280
    Is this not correct? Is there another way to accomplish the end result? Or am I doing it wrong? Thanks for your help.
    Nothing wrong with that method, just make sure the path to your Download directory is correct in both configure.php files ...
    I believe they are correct. That is the problem. They should be correct but the attributes are still not quite linking up correctly. I will include what I have for those 2 files for your review to make sure I have done it correctly.
    In the /admin/includes/configure.php:
      define('DIR_FS_DOWNLOAD', '/home/username/');
    In the includes/configure.php:
    Keep in mind that the download folder will be specified in the attribute file path itself to complete the download path.
    (Example: "download folder"/file_name.zip)
    My understanding is this would allow for multiple manufactures to upload their own files and have their own "download folders" to upload to without having access to the other manufacturers files.
    Let me know if I need to change this. Thanks again for your help.
    You are sure it is:
    /home/username/
    and not something like:
    /home/username/public_html/
    or something like:
    /home/username/public_html/shop/
    Go to the Admin and check the Tools ... Server Info ... and see what the:
    DOCUMENT_ROOT
    is for the full path ... and compare to the:
    SCRIPT_FILENAME
    to see if you need an additional directory in there ...
  7. #17
    I was inputting it as /home/username/ because the tutorial I listed instructed to do this so that the downloads folder is not accessible from the internet.
    If I input it as /home/username/public_html/ or /home/username/public_html/shop/ the downloads folder will be accessible from the internet correct?
    If I am wrong on this let me know. I just assumed this needed to be done since it instructed to do this in the tutorial I shared. I will check what you have listed above though to double check.
  8. #18
    I do not know where you have your Download directory ...
    Make sure that the path that you use it the correct one based on where you put your Download directory and what you call it ...
    The, make sure it is in both configure.php files so that they both can see it correctly ...
  9. #19
    She did have her downloads folder in the public_html/store location which was accessible to internet hackers. I have moved the downloads folder above the public_html location so it is no longer accessible. The file path I would need to use in both configure.php files is home/username/... correct?
    What am I missing here? Both configure files have the file path of home/username/ and the specific folder in the location is stipulated in the attribute file path. So what am I missing? Probably something really simple. Sorry to be so repetitive.
  10. #20
    I have mine site in a subdirectory ... like www.my_domain_name.com/store
    I change the define for the Download Directory to be above the public_html and in a different directory name, in this case the the S on the end of downloads and use in both configure.php files:
      define('DIR_FS_DOWNLOAD', '/home/myusername/downloads/');
    I enter the Download filename on the Attribute as either:
    test.zip when in the /home/myusername/downloads
    or when in a subdirectory ...
    otherdirectory/test.zip when in the /home/myusername/downloads/otherdirectory
    Note: my define for the directory name has the / on the end of it ...
  1. Easy Populate 1.2.5.5 with Stock With Attributes Help please
    By shahram in forum All Other Contributions/Addons
    Last Post: 4 Oct 2012, 07:56 PM
  2. Attributes Display problem...need some help please.
    By Zadris in forum Setting Up Categories, Products, Attributes
    Last Post: 23 Oct 2011, 05:20 AM
  3. Need help with attributes Please
    By bromleysid in forum Setting Up Categories, Products, Attributes
    Last Post: 16 Aug 2009, 05:03 PM
  4. Add to Cart Not Appearing with Products with Attributes. Please help me!?!?
    By alegria in forum Setting Up Categories, Products, Attributes
    Last Post: 26 Jun 2008, 11:46 PM
  5. Help with attributes please
    By duquecigars in forum General Questions
    Last Post: 14 Apr 2008, 10:41 PM
