Results 21 to 30 of 39
  1. #21
    Sep 2004
    Default Re: PHP 5.4 warnings: Illegal string offset
    Assuming there were no other code change dependencies in play,
    I tested the new code in the two github links posted above on a a ZC 1.51 shop:
    1. RE: https://github.com/zencart/zencart/c...2cb78fc86946c9
    Tested the code changes in twelve files on above github page
    After editing the twelve files, added virtual download products to shopping cart, then clicked "Go to Checkout", then observed the following error:
    https://domainname/shop/index.php?ma...ckout_shipping
    Error in Firefox: "The page isn't redirecting properly. Firefox has detected that the server is redirecting the request for this address in a way that will never complete. This problem can sometimes be caused by disabling or refusing to accept cookies."
    I ensured Firefox was not blocking cookies, and indeed, checking out with download products in the cart worked before updating the twelve files. I observe the same result in IE.
    Had no issue checking out with physical products.
    2. In regards to the file update for tpl_checkout_shipping_default.php
    The github change code for the above file shows "$checked = FALSE;" as a pre-existing line of code.
    // set the radio button to be checked if it is the method chosen
    $checked = FALSE;
    however, this line does not already appear in the zc 1.51 stock file.
    And yet github does not show the line of code "$checked = FALSE;" as new
    (not displayed in green with a "+" symbol) indicating it should be added.
    I went ahead added that code line.
    3. Re: https://github.com/zencart/zencart/c...6deb80026d2886
    Employed the code changes in /includes/functions/sessions.php
    Following that, I observed the sessionid (zenid) was no longer appended to the shop URL while navigating through the shop (and user tracking mod logs showed the same).
    Observed no related error or warnings in either the server error log or zc logs.
    Reverting to the stock sessions.php, zenid was again employed.
  2. #22
    Apr 2010
    My understanding, is that the two github posts, are the changes made to 1.6.0, not the changes that we need to make to 1.5.0, or 1.5.1
    I made the changes discussed in the posts here, and that is what worked. I am still running 1.5.0
  3. #23
    Apr 2010
    I made all of the file changes discussed on the first page, and I am now getting this error again:
    [04-Dec-2013 15:49:10 America/Denver] PHP Warning: Illegal string offset 'cost' in /home2/redsauto/public_html/includes/classes/order.php on line 355
    There are only 3 of these in my cache, when I have had 19 orders since I switched to php 5.4
    How do I determine what is setting this error now, being that it is such a low occurrence?
  4. #24
    Quote Originally Posted by vanhorn_s View Post
    Of the 19 orders, were 3 of them using a different shipping method?
  5. #25
    Jul 2007
    lat9 some of my client are still getting lots of error logs to after making all the changes. I'm not sure about the shipping method. Any ideas
    Is your site Upgraded to the current version 1.5.4 Yet?
    zencart-upgrades-website-installation
  6. #26
    countrycharm: Which changes are "all the changes"?
  7. #27
    Jul 2007
    I already stated it here.
    http://www.zen-cart.com/showthread.p...10#post1224510
  8. #28
    Apr 2010
    They have all been USPS
  9. #29
    The changes made for Zen Cart v1.5.2 were much more "intense" that those that I proposed in this thread. Please see https://github.com/zencart/zencart/c...2cb78fc86946c9 for the full set of changes made to v1.5.2 surrounding this issue.
  10. #30
    Mar 2005
    Waxahachie, Texas
    What is the impact of this error? Does it prevent the order from being completed, or just have the possibility of incorrect data? (We use flat-rate shipping, so we shouldn't be invoking any special calculations; however, we've had 10 of these errors within the past 2 months.) The fix appears extensive, and I don't want to break my store applying the fix (I'm good at that) if it's not a severe problem.
    Ray
  1. Illegal string offset 'id' in order.php
    By marcopolo in forum General Questions
    Last Post: 25 Jul 2015, 04:31 PM
  2. Replies: 9
    Last Post: 23 Mar 2015, 08:42 AM
  3. v153 Illegal string offset 'id' in order.php
    By jeking in forum General Questions
    Last Post: 5 Sep 2014, 07:32 PM
  4. v151 PHP Warning: Illegal string offset 'id'
    By Nettric in forum Bug Reports
    Last Post: 30 May 2014, 06:53 AM
  5. Replies: 1
    Last Post: 30 Sep 2013, 07:39 PM
