Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Jan 2013
    Default Re: Language problem
    well if it can help you, I`ve had to delete and start over a few times over the last week... but thanks to Torvista, I figured out half of my problem. How are you tying in your special caracter...
    ex: é : like this
    é
    or like this
    é
    it turned out I had the right coding when using é but had reverted to the é form after thinking I had found the right information.
    So basically, that took care of part of the problem for me.
    The rest of the problem is that the cart is perfect and showing properly when the customer isn`t logged in... as soon as I log in as a customer... the text is once again corrupted and doesn`t appear to be utf-8... so I`m searching still.
  2. #22
    Feb 2013
    Zürich / Switzerland
    Hallo
    I installed ZENCART 1.5.4 and I have also same Problem. Can somebody help me please ??
  3. #23
    Quote Originally Posted by ugurli View Post
    Hallo
    Good day to you. While you may be experiencing the same result as the two above, more than likely the setup of your store is different than theirs. Please read through the thread, answer the same questions that have been asked as well as the posting tips that appear just above the text entry box.
    This information will help others help you.
  1. Language Problem
    By Rasyr in forum General Questions
    Last Post: 2 Aug 2010, 03:56 PM
