By what methodare you trying to enable/disable? Just clicking on the red/green button when looking at the list of products/categories? That's related to a file setup in that file. Last time I helped someone with that, I said it was a PoST/GET issue, then realized that there was a thread that talked about an early problem (no longer existent) with Image Handler (all because the code for that plugin was of an older version of ZC), the thread had a fix link in it and while it discusses IH, it is all about the file that is probably giving you trouble.
On the other side of things, and a little slower, you should still be able to change the status when reviewing the product. (First set of radio buttons). I'll look for the thread and see if I can find it again.
As for your required attribute(s), I went to the one product initially provided, I entered nothing, and when selecting add-to-cart, sure the "cart" appeared, but it was empty. Same as when I selected a date, but once I select a quantity, then it got added to the cart. At no time did I receive any type of error message, which was a bit of a surprise. Anyways, what is it that you are trying to make required again? Normally when something is required the template changes the surrounding text to show like an asterisk (*) or something. Don't see anything indicating any required attributes.
