Results 1 to 3 of 3
    Mar 2014
    Central California
    Default needing basic installation help for templates
    I am brand new to Zen Cart and I'm having problems with installing a template, Brighton Pets.
    Zen Cart is installed in the /public_html/my_store folder. I use Directnic and they install it for me.
    I have used FileZilla to upload the "includes" folder to what I believe is the root folder, public_html
    I then go to tools >Template Selection >Edit, and the template is not there.
    I also tried putting the "includes" folder into the my_store folder and it works. Which folder does Zen Cart
    consider the "root" folder.
    ken1
    Default Re: needing basic installation help for templates
    The "root" folder for Zen Cart is the folder its files and folders sit in; for you it would be /my_store/.
    Unless there is a strong reason to do otherwise, it would be best for you to install or move your Zen Cart into /public_html/ so that visitors to your store only need to enter yourdomain.com and not yourdomain.com/my_store/. It is neater and simpler all around.
    http://www.zen-cart.com/content.php?...that-directory
    Jan 2014
    Ontario, Canada
    Hi Ken1
    Make sure you have uploaded the following file:
    includes/templates/YOUR_TEMPLATE/template_info.php
    Only after that has been published, can you select the desired template from your admin -> tools -> template selection
    Hope that helps too...
  1. v155 Needing help setting up my taxes for cities within Texas
    By wmorris in forum Currencies & Sales Taxes, VAT, GST, etc.
    Last Post: 8 Jun 2016, 01:54 AM
  2. v150 Needing help changing Image Handler for a CDN (Content Delivery Network)
    By trinorthlighting in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Sep 2013, 12:10 AM
  3. Errors in Basic Installation
    By MAtkins in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Mar 2009, 06:44 PM
  4. Basic installation help
    By jaffe1 in forum Basic Configuration
    Last Post: 18 May 2006, 12:57 AM
