And since it didn't work, I also added init_includes, overrides, init_html_editor.php.... since that was included in the download but not in the instructions. Still nothing!
What is the text that you are trying to paste in? Also, there is a setting in the My Store area, to default the editor to ckeditor:
Admin->My store->HTML Editor.
At one point there also was some additional code that had to be added to the product info page to enable ckeditor in those areas; however, I do not recall if that is still necessary...
So, I reached out, and was granted access to the admin panel... While I am truly limited in correcting the issue, I have identified that there is a discrepancy in one of the CKEDITOR files... (May or may not have been in the instructions somewhere, but regardless.)
Per the developer's toolkit, and looking at the page source on a page that should have an editor. If you open/modify includes/ckeditor.php around line 21 or 22 (Depends on if you have fixed the 1 line number discrepancy with v1.5.x), changing
to:Code:<script type="text/javascript" src="../<?php echo DIR_WS_EDITORS ?>ckeditor/ckeditor.js"></script>
Then once that is complete, feel free (and suggested) to change up the username/password that was provided, as well as rename the admin directory (and if necessary) update the htaccess for the same.Code:<script type="text/javascript" src="<?php echo DIR_WS_EDITORS ?>ckeditor/ckeditor.js"></script>
Also, take note of the plain text that was added to the test product, both before it is displayed and how it is on the site... Used an escape code.
Last edited by mc12345678; 21 Mar 2014 at 12:04 AM. Reason: Made a mistake in my original path location
I put everything in the administrator folder now for CKEditor. It still doesn't show up. I'm about to give up!
