Can we please now concentrate on MY problem!
The above to be taken with humor, as seriously the f12 discussion doesn't bother me, and I always appreciate the efforts of you people.
Nah. It seems like too much work. <g>
OK, so I've nothing definitive for you, mainly on account of the fact that I've identified a number of differences between the various sites, the most confusing (to me) is the inconsistency of your /template/ folder naming convention(s).
For example, one of the sites has the jscript in a folder afz_zc_mulk_17, another is apparently using afz_zc_mulk_17 & afz_zc_mulk_18, and another afz_zc_05.
This is all fine if you know exactly what site should be using what, but as an outsider looking in, it makes it a little difficult to follow what is going on where.
In addition to this, and assuming the folders are correct for any given site/store, I did notice one thing that I consider would/could be the source of the problem, and that is with the name of the file for the lQuery 'Sizzle' library.
On the site(s) that work function correctly, this file is called "jscript_a_jquery.js", and the site(s) where it isn't working has this file called "jscript_a_jscript" (which is giving a file not found).
I don't have a clue how or where this library relates to the cookie script. or if it is related at all - but it seems like it has something to do with CSS selectors, and since the cookiescript would (I assume) depend on .CSS for it to work, there is a good possibility that this is the cause.... or not.
Anyway, before I delve any deeper into this I really would like to see a little bit more consistency in where the jscript/jquery files are located.
RodG
LOL
Why do you think I asked you guys?
Seriously: Thank you.
The template naming is ok, I mean I'm using different templates for each site, the references too were ok, I had left the reference to an older template, but thanks to your note I cleaned it up, and now is less confusing.
The jscript_a_jquery file was there, the problem was that it was called twice as I had forgotten to remove one of the instances, which I noticed going after your notes, and suggestions.
After clean up all seems to be fine and working.
I removed it as I need to fine tune it a bit, but it works.
Thank you again, and glad you did MOST of the work for me! ;)
I also have problems with this add. I uploaded the 2 jscript files and placed the cookie_consent_snip before the </body> tag.
Didn't changed anyhing else, but nothing is showing.
With F12 i get this error: Uncaught TypeError: $.cookiesDirective is not a function
Anyone has any idea how to get this working?
The website is: restyleparts.com
Same here.
Uploaded both the .js files and the file from the language directory, added the snippet to the end of the tpl_main_page.php file just before the </body> tag.
I get the error about TypeError: undefined is not a function (evaluating '$.cookiesDirective') as well and would love to know how to solve this so the plugin works and shows people there are cookies on our site.
Site can be found at www4. carmo.nl (the 4 is needed, it's the test site)
Above was also begun as a discussion in the following thread: https://www.zen-cart.com/showthread....Cookie-warning
