**This has already been posted in the Hope Free Template section but I thought this part of the forum is the proper place for templates. Hope admin won't get too irritated!
This is the template I eventually want: http://zen4me.com/demo/hope/
Following the instructions in the README file, the new template doesn't show up alongside the default one in the admin drop-down list.
I'm running things locally, using WAMP server. I've installed other templates and they do show up. The missing item is an issue I've had before but I moved on to other templates. Now I've found this template, I want it but it's a no-show.
My file structure is C:\wamp\www\zencart\includes\templates
Before I copied over the zipped folder, the default in that folder was two directories: 'classic' and 'template_default'.
As per the instructions, I copied over 'zen4me.com-hope-free-template' and went to admin/tools/template selection and observed only 'Classic Contemporary Green', the default template.
I'm using Zen Cart v1.5.4 and everything else seems OK with this local setup.
Any ideas on how I can get this template working? I'll keep trying to fix this, but in the meantime I hope someone can help.
Template download: http://www.zen4me.com/files/zen4me.c...e-template.zip
Thanks...
