That was added in earlier versions of the DIY responsive components.Is `show_box_min_width` tinyint(1) NOT NULL DEFAULT '1' applicable to v155 or 160?
It was not ported to v1.5.5
Ok. I can edit individual side boxes. Thank you.
Ability to add to cart is gone.
Do I need to run the new zc installer?
Cheers!
v2.0+
Still, I cannot add to or edit cart again. No debugs in the logs folder.
Any advice?
Cheers!
v2.0+
webskipper, can you put a fresh new unaltered v155 install (with demo data) into a subdirectory for us to compare against your live site?
I moved the top to the 155 Responsive feedback topic.
Cheers!
v2.0+
Oy, I don't see how this is specific to the 155 Responsive Classic template
deleted
Cheers!
v2.0+
Cheers!
v2.0+
Um, we talked about this already. The auto increment on the layout_boxes table. ... you'll need to first delete all the entries with layout_box_id = 0, and then set that field to be autoincrement. Then you can do a reset to recreate all the zeros just deleted, and it should let you save changes again.
I misunderstood you the first time, Doc.
So, what you are saying is reset all int(#) to zero? For all tables as well? Right column boxes do not show.
DROP TABLE IF EXISTS `layout_boxes`;
/*!40101 SET @saved_cs_client = @@character_set_client */;
/*!40101 SET character_set_client = utf8 */;
CREATE TABLE `layout_boxes` (
`layout_id` int(0) NOT NULL AUTO_INCREMENT,
`layout_template` varchar(64) NOT NULL DEFAULT '',
`layout_box_name` varchar(64) NOT NULL DEFAULT '',
`layout_box_status` tinyint(0) NOT NULL DEFAULT '0',
`layout_box_location` tinyint(0) NOT NULL DEFAULT '0',
`layout_box_sort_order` int(0) NOT NULL DEFAULT '0',
`layout_box_sort_order_single` int(0) NOT NULL DEFAULT '0',
`layout_box_status_single` tinyint(0) NOT NULL DEFAULT '0',
PRIMARY KEY (`layout_id`),
KEY `idx_name_template_zen` (`layout_template`,`layout_box_name`),
KEY `idx_layout_box_status_zen` (`layout_box_status`),
KEY `idx_layout_box_sort_order_zen` (`layout_box_sort_order`)
) ENGINE=MyISAM AUTO_INCREMENT=99 DEFAULT CHARSET=utf8;
/*!40101 SET character_set_client = @saved_cs_client */;
Do you also want ENGINE=MyISAM AUTO_INCREMENT=117 DEFAULT CHARSET=utf8; to be?
ENGINE=MyISAM AUTO_INCREMENT=0 DEFAULT CHARSET=utf8;
I think I found an error on my end because downloading the backup copy of the DB does not show the changes I make i.e adding auto_increment. I delete all the lines above the first instance of DROP TABLE IF EXISTS `address_book` and also below the last instance of UNLOCK TABLES. Copy pasted file directly into admin sql, correct?
Cheers!
v2.0+
