Haggis, do your products have attributes? Because if so, this gets a bit tricky.
If you have two attributes, each of which has two choices, you have four potential combinations.
But the product only has a single model number.
Does this make sense?
It may, but it is also possible to apply/store a customid to each such variant, if in fact this is what is going on. Otherwise it appears that even with such "attributes" that perhaps the product are being "listed" one by one instead of being combined into attribute related product... (Yes I'm making guesses.)
Can you share this spreadsheet so that we can see what it is you are attempting first hand?Currently the spreadsheet reacts to what options are chosen on a dynamic basis
No need. He's using attributes, so we know enough to direct him.
@Haggis, the products_model field is a single-valued field per model. What you'll need to do is create a new field in your database (suggest using the orders_products table) and populate your computed "model number" based on attribute settings when an order is placed (or perhaps nightly as a cron job). You'll have to write the logic that maps the product and its attributes to one of your model numbers.
