Results 1 to 10 of 16
    May 2016
    St. John's NL Canada
    Default [Done v155a and v155b] AdminRequestSanitizer Problem
    Problem is occurring with ZC 1.5.4 and 1.5.5a (skipped 1.5.5).
    The base Zen Cart is heavily modified; however, this problem is only showing up for one aspect: Reviews. Specifically, my version of .../admin/includes/backend/reviews.php (NB my admin directory is called backend).
    The error log shows:
    [30-May-2016 21:33:39 America/Detroit] Request URI: /backend/reviews.php?page=16&rID=498&action=preview, IP address: 47.55.233.182
    #1  AdminRequestSanitizer->filterProductNameDeepRegex()
    #2  call_user_func() called at [/home/amistad/public_html/backend/includes/classes/AdminRequestSanitizer.php:290]
    #3  AdminRequestSanitizer->processBuiltIn() called at [/home/amistad/public_html/backend/includes/classes/AdminRequestSanitizer.php:201]
    #4  AdminRequestSanitizer->runSpecificSanitizer() called at [/home/amistad/public_html/backend/includes/classes/AdminRequestSanitizer.php:180]
    #5  AdminRequestSanitizer->runSanitizers() called at [/home/amistad/public_html/backend/includes/init_includes/init_sanitize.php:232]
    #6  require(/home/amistad/public_html/backend/includes/init_includes/init_sanitize.php) called at [/home/amistad/public_html/includes/autoload_func.php:48]
    #7  require(/home/amistad/public_html/includes/autoload_func.php) called at [/home/amistad/public_html/backend/includes/application_top.php:171]
    #8  require_once(/home/amistad/public_html/backend/includes/application_top.php) called at [/home/amistad/public_html/backend/reviews.php:37]
    [30-May-2016 21:33:39 America/Detroit] PHP Warning:  Invalid argument supplied for foreach() in /home/amistad/public_html/backend/includes/classes/AdminRequestSanitizer.php on line 565
    Server information (screen-shot) is attached. Oh, this is the test site (1.5.5a) the live site is on 1.5.4.
    Despite this, the code does do what it is supposed to do. It supports creating reviews and editing reviews. An additional "status" (numeric) is supported and an additional column for reviews (review_type).
    I am not sure how to determine which field is causing the problem. Suggestions as to how to track this down would be appreciated. Currently I'm going to continue with other testing (and perhaps turn of sanitizing while doing that testing, to avoid sifting through the logs for other problems).
    JRG
    Default Re: AdminRequestSanitizer Problem
    Does your reviews.php, by chance, make use of an array of $_POST variables? What are the names of the $_POST variables that the plugin uses?
    Jun 2003
    Newcastle UK
    2
    Hi all
    This is in fact a problem with core code, and not really related to any plugins.
    The reviews code passes a 'products_name' hidden field which in this context is a string.
    However in general 'products_name' is expected to be an array (e.g. to account for language translations)
    Hence the sanitizer complaining it's not an array.
    Will push a fix up shortly
    May 2016
    I found your referenced thread after I had posted. The documentation link it has (http://docs.zen-cart.com/Developer_D...n_sanitization) is particularly helpful as it is the only real documentation I've been able to find on “admin sanitizing”.
    Thanks for trying to help — appreciated. More in my reply to the next response.
    May 2016
    Hello Wilt,
    I discovered the Admin Sanitizer documentation http://docs.zen-cart.com/Developer_D...n_sanitization. That allowed me to turn on sanitizer debugging messages. I matched the date-time stamp of one of the error logs to one for a debug message.
    You undoubtedly have found the real problem. I did notice, however, that in the debug message, the admin sanitizer has changed the value of the "type_name" variable (stripping out spaces and a slash — but leaving a dash). This can be seen in the posted sanitizer debug message.
    This is only a problem because I display the type_name. I created additional product types as the subject site deals exclusively in downloadable products: e-books and software (which can be thought of as “interactive e-books”). I am going to resolve this problem by making sure the type_name is a single word (I'll manually change the database to accomplish this).
    I am looking forward to a fix.
    Oh, turning off "strict sanitizing" doesn’t stop the sanitize error messages, which I am sure you know.
    A question, if I may: It seems to me, on reflection, that the Admin Sanitizer documentation implies I should set up data files in /admin/includes/extra_datafiles/ (for me, /backend/…) to define how the Admin Sanitizer should handle any additional GET or POST fields I have added to the Admin core. It doesn’t indicate how the file names should be formed. Could you tell me please? And whether they are necessary (i.e. advised for good security)?
    May 2016
    It wasn’t necessary to manual change the database. Instead, in Admin, Catalog—>Product Types
    Wilt: Sorry, I didn’t realize I hadn't posted the sanitizer log. If you want it, I can reproduce it.
    7
    Quote Originally Posted by wilt View Post
    Hi all
    Wilt's fix is the 3 files mentioned here: https://www.zen-cart.com/showthread....33#post1312333
    May 2016
    Thank you for the link. I shall apply the fixes to both the live and test sites.
    Jun 2005
    Cumbria, UK
    I need to enclose some text in html tags, in the Option Names Comments field, but when I put the tags in, it is not sanitizing and converts the < to &lt; , and the > to &gt; . I have to then go into the database and change them back to < and > so that they do not render as &lt; and &gt; in-screen.
    eg: <hr /> becomes &lt;hr /&gt;
    How do I fix this?
    20 years a Zencart User
  1. [Done v155b] MasterCard 2-series BIN
    By jackie.taferner in forum Bug Reports
    Last Post: 9 Apr 2017, 09:34 PM
  2. v155 [Done v155b] Fax number on tpl_account_edit_default.php
    By istilah in forum Bug Reports
    Last Post: 12 Oct 2016, 01:36 AM
  3. Replies: 1
    Last Post: 12 Oct 2016, 01:22 AM
  4. v155 [Done v155b] admin css selector language-dependent
    By torvista in forum Bug Reports
    Last Post: 12 Oct 2016, 01:19 AM
  5. v155 [Done v155b] AJAX: Session-variable changes not saved
    By lat9 in forum Bug Reports
    Last Post: 18 Aug 2016, 12:20 PM
