Results 1 to 10 of 15
    Oct 2016
    Default In SSL Front Page can not connect with stylesheet and images
    Dear Professionals
    I have just did the installation 1.55 but somehow i have faced a problem which i can not solve. Admin Side is ok but front Side is having problem for connecting stylesheet and images.
    Please check link below to see the problem
    http://www.bakkerijmachines.eu
    Thanks in advance
    Default Re: Front Page can not connect with stylesheet and images
    What are the settings in /includes/configure.php for
    HTTP_SERVER
    HTTPS_SERVER
    ENABLE_SSL
    My suspicion is that your host is improperly configured and as a result ZC is detecting that the page(s) should be presented with https:. There are three ways that come to mind to resolve this. The first is the "easy" way which doesn't solve the underlying problem which is to change your HTTPS_SERVER. To have a path with http: in it. The second is to modify the code so that the <base tag resolves to the http: setup that is expected, the third is to contact the host and work through why particular values are coming up as true that is in the code that detects whether to present the page as https: instead of just as http:, oh I guess there is a fourth, you could buy a SSL certificate and serve all your pages as https... but from a code perspective that is unnecessary. From an eCommerce perspective the general recommendation is to have and use an SSL certificate.
    Oct 2016
    Thanks you, i will try and inform the result
    Oct 2016
    HTTP_SERVER
    HTTPS_SERVER
    ENABLE_SSL
    Configure as below; But still have problem. Main page loads normal but while surfing problem occurs.
    define('HTTP_SERVER', 'http://www.bakkerijmachines.eu');
    define('HTTPS_SERVER', 'https://www.bakkerijmachines.eu');
    * If you want to tell Zen Cart to use your HTTPS URL on sensitive pages like login and checkout, set this to 'true'. Otherwise 'false'. (Keep the quotes)
    define('ENABLE_SSL', '');
    * These DIR_WS_xxxx values refer to the name of any subdirectory in which your store is located.
    * These values get added to the HTTP_CATALOG_SERVER and HTTPS_CATALOG_SERVER values to form the complete URLs to your storefront.
    * They should always start and end with a slash ... ie: '/' or '/foldername/'
    Oct 2016
    Configure.php
    but problem still occurs
    2nd sorry i couldnt understand the things or codes to do
    3rd SSL certificate would be bought
    But i have some sites which were working good until last 3 weeks. I would lşke to understand and solve the case. It would be happen to some other zencart users too.
    Thanks your suggestions and solutions in advance
    Your configure.php file's ENABLE_SSL setting should be either 'false' or 'true' ... not ''! I believe that this is the source of your issue.
    Oct 2016
    I have just tried "true" and "false". But did not solve the issue.
    Nov 2005
    los angeles
    you have a definite hosting problem...
    i would first change this as such:
    define('HTTPS_SERVER', 'http://www.bakkerijmachines.eu');
    you do NOT have an SSL certificate properly installed, so you should not use https: until you get that done.
    for whatever reason, ZC is trying to load a number of your resources over https: and as that is not properly configured, the browser can not find the resource.
    i would try and get everything configured correctly using http: first. and then see about getting a SSL certificate properly installed.
    these 2 pages should look similar and they do not:
    as the second page gets redirected to a completely different site.
    good luck!
    author of square Webpay.
    See. Problem is, something within the following assignment is true such that $request_type is set to SSL. The test run by ZC is considered to be general enough to not miss that a site is setup to permit/show the content over a secure method, but also may misinterpret some signals because of the way the host has setup their system.
    Basically if any one of these following sections is true (code is from includes/init_includes/init_file_db_names.php) then the software will attempt to present the page using https.
    $request_type = (((isset($_SERVER['HTTPS']) && (strtolower($_SERVER['HTTPS']) == 'on' || $_SERVER['HTTPS'] == '1'))) ||
                     (isset($_SERVER['HTTP_X_FORWARDED_BY']) && strpos(strtoupper($_SERVER['HTTP_X_FORWARDED_BY']), 'SSL') !== false) ||
                     (isset($_SERVER['HTTP_X_FORWARDED_HOST']) && (strpos(strtoupper($_SERVER['HTTP_X_FORWARDED_HOST']), 'SSL') !== false || strpos(strtolower($_SERVER['HTTP_X_FORWARDED_HOST']), str_replace('https://', '', HTTPS_SERVER)) !== false)) ||
                     (isset($_SERVER['HTTP_X_FORWARDED_SERVER']) && strpos(strtolower($_SERVER['HTTP_X_FORWARDED_SERVER']), str_replace('https://', '', HTTPS_SERVER)) !== false) ||
                     (isset($_SERVER['SCRIPT_URI']) && strtolower(substr($_SERVER['SCRIPT_URI'], 0, 6)) == 'https:') ||
                     (isset($_SERVER['HTTP_X_FORWARDED_SSL']) && ($_SERVER['HTTP_X_FORWARDED_SSL'] == '1' || strtolower($_SERVER['HTTP_X_FORWARDED_SSL']) == 'on')) ||
                     (isset($_SERVER['HTTP_X_FORWARDED_PROTO']) && (strtolower($_SERVER['HTTP_X_FORWARDED_PROTO']) == 'ssl' || strtolower($_SERVER['HTTP_X_FORWARDED_PROTO']) == 'https')) ||
                     (isset($_SERVER['HTTP_SSLSESSIONID']) && $_SERVER['HTTP_SSLSESSIONID'] != '') ||
                     (isset($_SERVER['HTTP_X_FORWARDED_PORT']) && $_SERVER['HTTP_X_FORWARDED_PORT'] == '443') ||
                     (isset($_SERVER['SERVER_PORT']) && $_SERVER['SERVER_PORT'] == '443')) ? 'SSL' : 'NONSSL';
    Recently seen is when a host has setup a proxy server and haven't properly setup variables/constants correctly such as HTTP_X_FORWARDED_BY and having it set such that it is the same content as what is used for connecting to the https server. Problem is, that when there is no SSL assigned to the site, then that should not evaluate to be true. It could be other such comparisons, but there is a thread around here that describes how to setup a file to put on your server, tell your host to access the file and either explain why or correct the server settings until all is right.
    But the "quick" fix would be to modify your HTTPS_SERVER setting in the includes/configure.php file as already suggested.
    Would also agree to use false instead of the pair of single quotes just for consistency to the concept that is generally addressed as a boolean and the instruction of using true or false not true and left empty or something similar.
  1. Can not get USPS shipping to connect with Google Checkout
    By CTBob in forum Built-in Shipping and Payment Modules
    Last Post: 9 Feb 2011, 05:14 PM
  2. Replies: 1
    Last Post: 12 Jan 2009, 01:39 PM
  3. Help with SSL and Admin Page Not Working
    By chuck68tx in forum Basic Configuration
    Last Post: 22 Aug 2008, 05:37 AM
  4. help! Images not showing on front page
    By innerstatejt in forum Customization from the Admin
    Last Post: 5 Dec 2006, 10:35 PM
