On the very first step to use that tool, it says "* 1. Make sure the DIR_FS_SQL_CACHE setting is correct in your /includes/configure.php file." One thing i had noticed as a difference between the configure.php file from my "storetest" and my "challengemehq" (aside from the URL and DB info that WAS edited) was that there was no information for that cache line. Currently, it reads like this:
* Advanced use only:
* The following are OPTIONAL, and should NOT be set unless you intend to change their normal use. Most sites will leave these untouched.
* To use them, uncomment AND add a proper defined value to them.
// define('DIR_FS_SQL_CACHE' ...
// define('DIR_FS_DOWNLOAD' ...
// define('DIR_FS_LOGS' ...
While the existing "storetest" file (the copy i saved aside from it) reads this:
define('DIR_FS_SQL_CACHE', '/home/creat419/public_html/creationcassel.com/storetest/cache');
So, when the instructions to use the Fix cahe key says to make sure the setting is correct, should i add those lines "back"? It is obviously NOT correct NOW in the active configure.php file since it is NOT THERE.
