Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
    Hoedspruit
    Default Re: Blank site after installing using Plesk control panel
    Here is the install log
    Nov 20 2017 15:08 -- inspect
    System Inspection Results:
    WARN: Zen Cart Version: => New Version Available v1.5.5e :: v155e contains minor updates
    <a href="https://www.zen-cart.com/showthread.php?219730-Zen-Cart-v1-5-5e-released!#post1326850
    " target="_blank">Download Here</a>
    NA: Webserver => Apache
    NA: HTTP Host => joburgonline.com
    NA: Path_Translated => /var/www/vhosts/joburlnx.ehost-services221.com/public_html/zc_install/index.php(SCRIPT_FILENAME)
    NA: Real Path => /var/www/vhosts/joburlnx.ehost-services221.com/public_html
    NA: Server Free Disk Space => 93.33 GB
    NA: PHP O/S => Linux
    NA: PHP API Mode => cgi-fcgi
    NA: PHP Max Execution Time per page => 600
    NA: Disabled PHP Functions => , dl, exec, passthru, pcntl_exec, popen, posix_kill, posix_mkfifo, posix_setuid, proc_close, proc_open, proc_terminate, shell_exec, system, ftp_exec, leak, posix_setpgid, posix_setsid, proc_get_status, proc_nice, show_source, escapeshellcmd
    OK: MySQL Support => ON
    OK: PHP Version => 5.6.31
    OK: PHP Sessions Support => ON
    OK: PHP Session.AutoStart => OFF
    OK: PHP session.use_trans_sid => OFF
    OK: Suggested SQL Cache Folder => /var/www/vhosts/joburlnx.ehost-services221.com/public_html/cache
    OK: PHP GD Support => ON
    OK: GD Version => GD bundled (2.1.0 compatible)
    OK: PHP ZLIB Compression Support => ON
    OK: PHP OpenSSL Support => ON
    OK: PHP cURL Support => ON
    OK: CURL NON-SSL Capability => Okay
    OK: CURL SSL Capability => Okay
    OK: PHP Upload Support => ON upload_max_filesize=16M; post_max_size=16M
    OK: PHP Upload TMP dir =>
    OK: Apache .htaccess Support => ON
    NA: PHP include_path => .:/opt/atomic/atomic-php56/root/usr/share/pear:/opt/atomic/atomic-php56/root/usr/share/php
    NA: PHP SMTP destination => localhost
    NA: PHP sendmail path => /usr/sbin/sendmail -t -i
    NA: PHP sendmail 'from' =>
    WARN: PHP open_basedir restrictions => /var/www/vhosts/joburlnx.ehost-services221.com/:/tmp/
    OK: PHP Output Buffering (gzip) => ON
    OK: PHP XML Support => ON
    OK: PHP Session.Save_Path => /var/www/vhosts/joburlnx.ehost-services221.com/public_html/cache-->Writeable
    OK: includes/configure.php => Writeable
    OK: admin/includes/configure.php => Writeable
    OK: cache => OK 777 read/write/execute
    OK: images => OK 777 read/write/execute (INCLUDE SUBDIRECTORIES TOO)
    OK: includes/languages/english/html_includes => OK 777 read/write (INCLUDE SUBDIRECTORIES TOO)
    OK: logs => OK 777 read/write/execute
    OK: media => OK 777 read/write/execute
    OK: pub => OK 777 read/write/execute
    OK: admin/backups => OK 777 read/write
    OK: admin/images/graphs => OK 777 read/write/execute
    PHP Extensions compiled: Core, date, ereg, libxml, openssl, pcre, zlib, filter, hash, json, pcntl, readline, Reflection, SPL, session, standard, cgi-fcgi, bcmath, bz2, calendar, ctype, curl, dom, mbstring, fileinfo, ftp, gd, gettext, gmp, iconv, imap, intl, exif, mcrypt, mysqlnd, mysql, mysqli, odbc, PDO, pdo_dblib, pdo_mysql, PDO_ODBC, pdo_sqlite, Phar, SimpleXML, soap, sockets, sqlite3, suhosin, tidy, tokenizer, xml, xmlreader, xmlrpc, xmlwriter, xsl, zip, mhash, ionCube Loader, Zend OPcache, Zend Guard Loader
    Nov 20 2017 15:10 -- inspect
    Nov 20 2017 15:11 -- database_setup
    FATAL: Connection to Database failed -
    Nov 20 2017 15:11 -- database_setup1
    Installer - Page: database_setup -- collected information: Array
    [language] => english
    [DIR_FS_SQL_CACHE] => /var/www/vhosts/joburlnx.ehost-services221.com/public_html/cache
    [DB_TYPE] => mysql
    [DB_PREFIX] =>
    [DB_CHARSET] => utf8
    [DB_SERVER] => localhost:3306
    [DB_SERVER_USERNAME] => jobur_patrick
    [DB_SERVER_PASSWORD] => ***private***
    [DB_DATABASE] => joburlnx_***
    [SQL_CACHE_METHOD] => file
    Nov 20 2017 15:12 -- database_setup1
    [DB_TYPE] => mysql
    [DB_PREFIX] =>
    Used *** for [DB_DATABASE] name suffix
    Nov 2005
    los angeles
    look at my post above:
    https://goo.gl/cptm1a
    this was a permissions issue, and i have a feeling it remains a permissions issue.
    i would NOT worry about timezones at this time.
    feel free to donate money to carl or to the Zen-Cart Team
    Hoedspruit
    this really looks like a permissions issue:
    Directory index forbidden by Options directive: /var/www/vhosts/joburlnx.ehost-services221.com/httpdocs/
    if the user running apache can not view the files inside of this directory, ZC can not run.
    not sure how re-installing would change that. especially if doing the same process from the same automated installer.
    generally your hosting company can help with permissions issues.
    best.
    I misunderstood your post, but have read it through a few times now. I am grateful for your input Carl.
    Hoedspruit
    Hi Carl
    I have called our host and related the permissions issue to their agent.
    We changed a few settings, including the hosting settings to point the /httpdocs directory to the root directory for the site. In the latest install, the root directory is /joburgonline.com
    The site is in a shared hosting environment, so the /joburlnx.ehost-services221.com is a sub domain allowing me access to my control panel.
    We still have a blank site
    best.
    Nov 2005
    los angeles
    are there any new logs? please post them.
    do you have a .htaccess file in the root directory of your store? if so please post the contents of that file.
    Hoedspruit
    There are logs in both the site root folder and the home directory, 1 level up.
    There are tons of them - this one has a fatal error
    Nov 21 2017 4:00 -- inspect
    FATAL: store configure.php is not writeable
    NA: Path_Translated => /var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/zc_install/index.php(SCRIPT_FILENAME)
    NA: Real Path => /var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com
    NA: Server Free Disk Space => 93.14 GB
    OK: Current SQL Cache Folder => /var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/cache-->Writeable
    OK: Suggested SQL Cache Folder => /var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/cache
    OK: PHP Session.Save_Path => /var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/cache-->Writeable
    FAIL: includes/configure.php => <span class='errors'>Unwriteable</span>
    # @copyright Copyright 2003-2012 Zen Cart Development Team
    # @license http://www.zen-cart.com/license/2_0.txt GNU Public License V2.0
    # @version GIT: $Id: Author: DrByte Tue Aug 28 16:48:39 2012 -0400 New in v1.5.1 $
    # This is used with Apache WebServers
    # The following blocks direct HTTP requests to all filetypes in this directory recursively, except certain approved exceptions
    # It also prevents the ability of any scripts to run. No type of script, be it PHP, PERL or whatever, can normally be executed if ExecCGI is disabled.
    # Will also prevent people from seeing what is in the dir. and any sub-directories
    # For this to work, you must include either 'All' or at least: 'Limit' and 'Indexes' parameters to the AllowOverride configuration in your apache/conf/httpd.conf file.
    # Example:
    #<Directory "/usr/local/apache/htdocs">
    # AllowOverride Limit Options Indexes
    #</Directory>
    <Limit GET POST PUT>
    Order Allow,Deny
    Deny from All
    </Limit>
    ## NOBODY SHOULD BE SNOOPING IN THIS FOLDER
    # deny *everything*
    <FilesMatch ".*">
    Order Allow,Deny
    Deny from all
    </FilesMatch>
    IndexIgnore */*
  7. #17
    Nov 2005
    los angeles
    i still think this is a permissions issue or a configuration issue.
    the debug log is a system inspection log, which is not relevant assuming that the installation completed. unless the plesk was not able to write configure.php file. which is entirely possible.
    please post the contents of your includes/configure.php file. comment out the username and password for your DB selections.
    in addition, for now, change the name of your .htaccess file to something like htaccess_backup. i am not that well versed in apache redirects, but we should not need them to get ZC running.
    best.
  8. #18
    Nov 2005
    los angeles
    this does work:
    http://joburgonline.com/extras/ipncheck.php
    so we know the host is pointing to the correct directory.
    it is probably the includes/configure.php file.
    best.
  9. #19
    Hoedspruit
    this does work:
    best.
    The includes/config.php permissions are read only - is that correct? If not, please advise.
    * @package Configuration Settings circa 1.5.4
    * @copyright Copyright 2003-2014 Zen Cart Development Team
    * File Built by zc_install on 2017-11-21 03:50:36
    define('HTTP_SERVER', 'http://joburgonline.com');
    define('HTTPS_SERVER', 'https://joburgonline.com');
    define('DIR_WS_PHPBB', '/');
    define('DIR_FS_CATALOG', '/var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/');
    //the following path is a COMPLETE path to the /logs/ folder eg: /var/www/vhost/accountname/public_html/store/logs ... and no trailing slash
    define('DIR_FS_LOGS', '/var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/logs');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', '');
    define('DB_CHARSET', 'utf8');
    define('DB_SERVER', 'localhost:3306');
    define('DB_SERVER_USERNAME', '');
    define('DB_SERVER_PASSWORD', '');
    define('DB_DATABASE', '');
    define('SQL_CACHE_METHOD', 'file');
    define('DIR_FS_SQL_CACHE', '/var/www/vhosts/joburlnx.ehost-services221.com/joburgonline.com/cache');
    // EOF
  10. #20
    Nov 2005
    los angeles
    read is fine.
    did u rename the htaccess file?
    please post the newest debug log.
  1. admin panel blank after installing addon
    By loaner in forum All Other Contributions/Addons
    Last Post: 19 Aug 2011, 09:08 PM
  2. Accessing Old Control Panel After Moving Site
    By sirluck in forum General Questions
    Last Post: 14 Apr 2009, 11:41 PM
  3. Replies: 2
    Last Post: 2 Feb 2008, 07:32 PM
