I'm trying to upgrade my old 155b version to the new 155f version. Using phpmyadmin, I create the new database ( using zc_install). Then I go to the old database ( that is live ), and export the database to an sql file, just as I have done several times before. I then import the data to the new database, it gives me a success message. I check the tables on the new database, and nothing has changed. I've blown away the new DB, completely re-installed zc, and still can't import anything.
My skills aren't great, but I've managed to upgrade several times in the past, so now I'm at a loss. Any help would be appreciated.
