Are you sure you removed it from the correct file?
Zen cart installation / maintenance / customisation / hosting
Supported Modules: Dutch language pack, Multi site, Dynamic Price Updater and more.
public_html/includes/templates/mobishop_orange/css/stylesheet_columnar_pr.css
this is where I removed it from.
And thank you so very much for spending this time on this problem
NO its still there....
https://bestfarmparts.com/includes/t...olumnar_pr.css
Code:#productListing {padding-bottom: 25px;} .centerBoxContentsProducts .c-product-wrp { min-height: 305px; padding: 10px 10px 5px; } .centerBoxContentsProducts .button_buy_now {display: inline-block;} .listingDescription {display: none;} h3.itemTitle { text-align: center; padding-bottom: 3px;} .centerBoxContentsProducts .c-product-wrp img { padding: 10px 0;} .table-price { padding: 2px 0 5px; display: block; } #gridSorter {margin: 1px 0 8px; padding: 4px 8px; background: #f3f3f3; border-bottom: 1px solid #ddd;} #gridSorter ul {list-style-type: none; padding: 0; margin: 0; display: inline-block;} #gridSorter > span {display: inline-block;} #gridSorter ul li {display: inline-block; padding: 0 10px 0;} @media (max-width: 480px) { .centerBoxContentsProducts .c-product-wrp img {max-width: 100px !important;} }
ok, I am going to use the developers tool kit and find out what other file this is in and remove it from there also.
Ok, all is good now. I use a security firewall site that my site goes through. I just went there and cleared that cache.
Now it is working like it should. I was about ready to bust some chops when you kept telling me that line of code was there, when I knew that I had cleared it out. So it was the firewall site that had not cleared the cache yet. Probably would have cleared soon.
Thank you so much for putting up with me and getting this right. I really appreciate your help.
No problem, Your welcome. Troubleshooting can be a frustrating process
Where do I clear the cache? I just started having this same problem - description not showing
Which browser is being used? If you have another device or browser available that hasn't recently been used, should be able to try it to confirm that the problem is local machine cache related or not.
Also note that there are a lot of other resources available besides this forum to find direction on how to clear one's cache...
Now there's something EVERY purchased template should have. A display:none call for the product description.
NOT!!
