Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Jun 2012
    Default Re: $messageStack->add(...) in observer won't work
    mc12345678,
    Some further clarification please...
    The notes in includes/init_includes/init_observers.php refer to the naming convention of the class in includes/classes/observers/auto.xxxx.php as "zcObserver" + the camelcased xxxx string, and in includes/classes/class_base.php notes, the naming convention of the class method is "update" + camelcased xxxx string or just update. But I could also use the zc version below 1.5.3 method of freely naming the class zzzz in class file class.yyyy in includes/classes/observers with the method name of update, as long as the config.yyyy is present in includes/auto_loaders and it defines the class name as zzzz. Do I have this all correct?
    Also, if two or more observers are triggered by the same notifier, in what order are the observers executed? DrByte said in a post referring to zc 1.5.1 that the order of instantiation was the order of execution. Is that still true for zc 1.5.5 and what is the order of instantiation? Unfortunately, I could not determine the order of instantiation from a quick look at class_base.php.
    Thanks again for your help!
    Jun 2012
    Just wanted to correct the above post (correction in red)...
    The notes in includes/init_includes/init_observers.php refer to the naming convention of the class in includes/classes/observers/auto.xxxx.php as "zcObserver" + the camelcased xxxx string, and in includes/classes/class_base.php notes, the naming convention of the class method is "update" + camelcased notifier string or just update. But I could also use the zc version below 1.5.3 method of freely naming the class zzzz in class file class.yyyy in includes/classes/observers with the method name of update, as long as the config.yyyy is present in includes/auto_loaders and it defines the class name as zzzz. Do I have this all correct?
    Quote Originally Posted by Dave224 View Post
    To go slightly a step further and to be sure that x, y, z and the new w match up see the blue text edits below:
    The notes in includes/init_includes/init_observers.php refer to the naming convention of the class in includes/classes/observers/auto.xxxx.php as "zcObserver" + the camelcased xxxx string, and in includes/classes/class_base.php notes, the naming convention of the class method is "update" + camelcased notifier string or just update (when more than one notifier is present then it may be necessary to detect which notifier is present to take only the specific action for the specific notifier). But I could also use the zc version below 1.5.3 method of freely naming the class zzzz in class file class.yyyy in includes/classes/observers with the method name of update (note that any other functions in this file pre-1.5.3 can be called from the standard update method), as long as the config.wwww.php file is present in includes/auto_loaders, identifies the stored location of the class as being in the observers directory and it defines the class name as zzzz. Do I have this all correct?
  1. How do I add a coupon alert via messageStack for COWAO?
    By Dan123 in forum All Other Contributions/Addons
    Last Post: 9 Jul 2011, 01:05 AM
  2. uri mapping won't work on add to cart botton? help..
    By bryanblue in forum All Other Contributions/Addons
    Last Post: 25 Jan 2011, 03:27 AM
  3. $messageStack->add('gv_send'...
    By creative_mind in forum General Questions
    Last Post: 5 May 2010, 07:11 AM
  4. contact us won't work
    By mex in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Mar 2007, 11:30 PM
