I want to add stock by attributes to my shop. In the text for this it says:
BACK UP YOUR DATABASE and WEB SITE Files!
Prepare the package for upload to your server by renaming the following folders to match your template name: includes/modules/YOUR_TEMPLATE and includes/templates/YOUR_TEMPLATE.
If this is a new install of Zen Cart 1.5.1, then with most good FTP programs (such as FileZilla) you can simply drag and drop the admin (renamed to match your admin folder name) and includes directories into the root directory of your site. The files are already arranged in the correct directory structure. Upload the admin, and includes folder, to your store's directory. The "Instructions\InstallSQLcommands.txt" file is for those who wish to upgrade the database manually, DO NOT put the "Instructions" folder on your site, this is only for your reference.
Cannot find includes/modules/YOUR_TEMPLATE and includes/templates/YOUR_TEMPLATE. Do I just rename the admin and includes folders and put them in?
Is there an easier way to do this please?
