Results 1 to 10 of 14
    Feb 2019
    Yucca Valley, CA
    Default USPS shipping module will not return rates
    I am running two sites on the same server with two different USPS web accounts. One is v1.5.6 the other is v1.5.5.
    I've verified that both are in production mode. PHP version is in 5.6, but I have tried version 7.2 and 7.3. Server is running Centos 7. The error I get from USPS is:
    -2147219385DomPostageLibrary;RateV4.ProcessRequestThe requested Mail Service is only available when Ground Transportation is required, when the Zone is 5-9, or the mail piece is Oversized.
    View Source:
    USPS build: 2017-09-16 Server: production Quote Request Rate Type: Online Quote from main_page: checkout_shipping USPS Options (weight, time): --none-- USPS Domestic Transit Time Calculation Mode: NEW Cart Weight: 1 Total Quote Weight: 1.1 Pounds: 1 Ounces: 2 Maximum: 50 Tare Rates: Small/Medium: 10:0 Large: 10:0 Handling method: Box Handling fee Domestic: $0.00 Handling fee International: $0.00 Decimals: 3 Domestic Length: 8.625 Width: 5.375 Height: 1.625 International Length: 9.50 Width: 1.0 Height: 5.50 All Packages are Machinable: False Enable USPS First-Class filter for US shipping: True Sorts the returned quotes: Price-LowToHigh ZipOrigination: 92284 ZipDestination: 85281 City: Tempe State: Arizona Order SubTotal: $1.00 Order Total: $1.00 Uninsurable Portion: $0.00 Insurable Value: $1.00 RESPONSE FROM USPS: ==================================
    -2147219385DomPostageLibrary;RateV4.ProcessRequest The requested Mail Service is only available when Ground Transportation is required, when the Zone is 5-9, or the mail piece is Oversized.
    I'm not sure if it is a configuration error or a server problem.
    Default Re: USPS shipping module will not return rates
    It does not appear to be a server configuration issue. USPS has "clearly" identified what the package conditions need to be to use the method(s) selected for shipment. Could it be a configuration issue of the module? Sure. Things to review would be the settings for the USPS module, which box size(s) are checked, have there been any modifications in the minimum/maximum weights?
    Note that the zipcode pair provided is Zone 4 so doesn't match the criteria of zones 5-9. 1 pound weight doesn't seem that much and don't see anything that identifies that ground transportation is required, though the dimensions may be a little bit of an indicator of being oversized...
    Feb 2019
    Yucca Valley, CA
    I'm in California Zip 92284 and tried shipping to both Arizona Zip 85281 and CA in 92284. I'm not entirly sure show to get it to ship to all zones. I can find that setting in the module setup. I have the default shipping zone set to "none" I do not have package deminsions set for this item. I do have the weight set.
    I am not a shipping expert. This module used to work on my 1.5.5 zencart, then for some reason stopped working at some point. I'm not sure when.
    Feb 2019
    Yucca Valley, CA
    United States Postal Service
    You will need to have registered an account with USPS at https://secure.shippingapis.com/registration/ to use this module
    USPS expects you to use pounds as weight measure for your products.
    USPS Version Date
    2017-09-16
    Enable USPS Shipping
    True
    Full Name or Short Name
    Long
    Enter the USPS Web Tools User ID
    REDACTED
    Which server to use
    production
    Quote Sort Order
    Price-LowToHigh
    Handling Fee - US
    Handling Fee - International
    Handling Per Order or Per Box
    Box
    Decimal Settings
    3
    Tax Class
    --none--
    Tax Basis
    Shipping
    Shipping Zone
    --none--
    Sort Order
    All Packages are Machinable?
    False
    USPS Options
    --none--
    NEW
    USPS Domestic minimum Length
    8.625
    USPS minimum Width
    5.375
    USPS minimum Height
    1.625
    USPS International minimum Length
    9.50
    USPS minimum Width
    1.0
    USPS minimum Height
    5.50
    True
    Shipping Methods (Domestic and International)
    0, .21875, 0.00, 0, .8125, 0.00, First-Class Package Service - RetailTM, 0, .8125, 0.00, 0, .9375, 0.00, 0, 70, 0.00, USPS Retail GroundRM, 0, 70, 0.00, 0, 70, 0.00, 0, 70, 0.00, 0, 70, 0.00, 0, 70, 0.00, Priority MailTM Small Flat Rate Box, 0, 70, 0.00, Priority MailTM Medium Flat Rate Box, 0, 70, 0.00, Priority MailTM Large Flat Rate Box, 0, 70, 0.00, 0, 15, 0.00, 0, 20, 0.00, 0, 70, 0.00, 0, 70, 0.00, 0, 70, 0.00, 0, .21875, 0.00, 0, 4, 0.00, 0, 4, 0.00, 0, 66, 0.00, 0, 4, 0.00, 0, 4, 0.00, 0, 20, 0.00, 0, 20, 0.00, 0, 66, 0.00, 0, 4, 0.00, 0, 70, 0.00, 0, 70, 0.00
    Extra Services (Domestic)
    Certified MailRM, N, USPS TrackingTM Electronic, N, USPS TrackingTM, N, Insurance, N, Priority Mail Express Insurance, N, Priority Mail Insurance, N, Adult Signature Restricted Delivery, N, Adult Signature Required, N, Registered MailTM, N, Collect on Delivery, N, Return Receipt for Merchandise, N, Return Receipt, N, Certificate of Mailing (Form 3665), N, Certificate of Mailing (Form 3817), N, Signature ConfirmationTM Electronic, N, Signature ConfirmationTM, N, Priority Mail Express 1030 AM Delivery, N, Certified MailRM Restricted Delivery, N, Certified MailRM Adult Signature Required, N, Certified MailRM Adult Signature Restricted Delivery, N, Signature ConfirmationTM Restricted Delivery, N, Signature ConfirmationTM Electronic Restricted Delivery, N, Collect on Delivery Restricted Delivery, N, Registered MailTM Restricted Delivery, N, Insurance Restricted Delivery, N, Insurance Restricted Delivery (Priority Mail Express), N, Insurance Restricted Delivery (Priority Mail), N
    Extra Services (International)
    Registered Mail, N, Insurance, N, Return Receipt, N, Electronic USPS Delivery Confirmation International, N, Certificate of Mailing, N
    Retail pricing or Online pricing?
    Online
    Debug Mode
    Screen
    Aug 2009
    North Idaho, USA
    Are you shipping a 1 pound item and have a 10 pound tare weight? Did I misread it?
    Rick
    RixStix (dot) com
    aka: ChainWeavers (dot) com
    Feb 2019
    Yucca Valley, CA
    I believe it is 10% tare, but I may be mistaken.
    E
    Feb 2019
    Yucca Valley, CA
    It seems like zencart will not process the results that USPS returns and procees with the checkout.
    E
    Aug 2009
    North Idaho, USA
    My mistake. Misread. What service were you expecting to receive a rate? Which usps plugin version? Is there a mismatch between retail methods selected and online pricing?
    Rick
    RixStix (dot) com
    Feb 2019
    Yucca Valley, CA
    I've tried all the services. I've tried both retail and online pricing. Here is a new result that seams to not have an error:
    922849228402VARIABLEREGULAR1Priority Mail 1-Day&lt;sup&gt;™&lt;/sup&gt;7.356.95119Adult Signature Requiredtruetrue6.406.40120Adult Signature Restricted Deliverytruetrue6.666.66104Certificate of Mailing (Form 3817)truetrue1.451.45105Certified Mail&lt;sup&gt;®&lt;/sup&gt;truetrue3.503.50170Certified Mail&lt;sup&gt;®&lt;/sup&gt; Restricted Deliverytruetrue8.808.80171Certified Mail&lt;sup&gt;®&lt;/sup&gt; Adult Signature Requiredtruetrue8.808.80172Certified Mail&lt;sup&gt;®&lt;/sup&gt; Adult Signature Restricted Deliverytruetrue8.808.80103Collect on Deliverytruetrue7.757.75truefalse175Collect on Delivery Restricted Deliverytruetrue12.9512.95truefalse125Insurancetruetrue0.000.00truefalse179Insur ance Restricted Deliverytruetrue0.000.00truefalse109Registered Mail&lt;sup&gt;™&lt;/sup&gt;truetrue12.9512.95truefalse176Registered Mail&lt;sup&gt;™&lt;/sup&gt; Restricted Deliverytruetrue18.1518.15truefalse107Return Receipt for Merchandisetruetrue4.304.30108Signature Confirmation&lt;sup&gt;™&lt;/sup&gt;truetrue3.053.05173Signature Confirmation&lt;sup&gt;™&lt;/sup&gt; Restricted Deliverytruetrue8.258.25156Signature Confirmation&lt;sup&gt;™&lt;/sup&gt; Electronictruetrue2.602.60174Signature Confirmation&lt;sup&gt;™&lt;/sup&gt; Electronic Restricted Deliverytruetrue7.807.80190Special Handling - Fragiletruetrue10.9510.95106USPS Tracking&lt;sup&gt;®&lt;/sup&gt;truetrue0.000.00155USPS Tracking&lt;sup&gt;®&lt;/sup&gt; Electronictruetrue0.000.00
    View Source:
    USPS build: 2017-09-16 Server: production Quote Request Rate Type: Online Quote from main_page: checkout_shipping USPS Options (weight, time): --none-- USPS Domestic Transit Time Calculation Mode: NEW Cart Weight: 0.1 Total Quote Weight: 0.115 Pounds: 0 Ounces: 2 Maximum: 50 Tare Rates: Small/Medium: 15:.0 Large: 10:0 Handling method: Box Handling fee Domestic: $0.00 Handling fee International: $0.00 Decimals: 3 Domestic Length: 8.625 Width: 5.375 Height: 1.625 International Length: 9.50 Width: 1.0 Height: 5.50 All Packages are Machinable: False Enable USPS First-Class filter for US shipping: True Sorts the returned quotes: Price-LowToHigh ZipOrigination: 92284 ZipDestination: 92284-3429 City: Yucca Valley State: California Order SubTotal: $4.95 Order Total: $5.38 Uninsurable Portion: $0.00 Insurable Value: $5.38 RESPONSE FROM USPS: ==================================
    922849228402VARIABLEREGULAR1 Priority Mail 1-DayTM
    7.356.95
    119Adult Signature Requiredtruetrue6.406.40 120Adult Signature Restricted Deliverytruetrue6.666.66 104Certificate of Mailing (Form 3817)truetrue1.451.45 105Certified MailRMtruetrue3.503.50 170Certified MailRM Restricted Deliverytruetrue8.808.80 171Certified MailRM Adult Signature Requiredtruetrue8.808.80 172Certified MailRM Adult Signature Restricted Deliverytruetrue8.808.80 103Collect on Deliverytruetrue7.757.75truefalse 175Collect on Delivery Restricted Deliverytruetrue12.9512.95truefalse 125Insurancetruetrue0.000.00truefalse 179Insurance Restricted Deliverytruetrue0.000.00truefalse 109Registered MailTMtruetrue12.9512.95truefalse 176Registered MailTM Restricted Deliverytruetrue18.1518.15truefalse 107Return Receipt for Merchandisetruetrue4.304.30 108Signature ConfirmationTMtruetrue3.053.05 173Signature ConfirmationTM Restricted Deliverytruetrue8.258.25 156Signature ConfirmationTM Electronictruetrue2.602.60 174Signature ConfirmationTM Electronic Restricted Deliverytruetrue7.807.80 190Special Handling - Fragiletruetrue10.9510.95 106USPS TrackingRMtruetrue0.000.00 155USPS TrackingRM Electronictruetrue0.000.00
    But the cart will not prodeed beyond: https://shopinnovus.com/index.php?ma...ckout_shipping to the rest of check out.
    Feb 2019
    Yucca Valley, CA
    The plugin version is 2017-09-16. I've tried dongrading to 2016-01-17 K8
    It seames that the download for version Version: 2018-03-28 K10 on the website actually is version 2017-09-16 K10
  1. v139h USPS Shipping Module Not Returning Rates
    By WiccanWitch420 in forum General Questions
    Last Post: 10 Feb 2014, 05:23 AM
  2. USPS Shipping Module Error - will not allow priority on step 2
    By prodigious in forum Addon Shipping Modules
    Last Post: 11 Feb 2012, 03:07 AM
  3. How does the USPS module determine shipping rates?
    By NekkidFish in forum Addon Shipping Modules
    Last Post: 19 Jan 2012, 01:59 AM
  4. FedEx Module will not show non-home rates.
    By gcntim in forum Addon Shipping Modules
    Last Post: 16 Jan 2010, 12:09 AM
  5. USPS will not return International postage costs for me
    By Mike Kelly in forum Built-in Shipping and Payment Modules
    Last Post: 28 Sep 2007, 03:20 PM
