    Jun 2007
    red flag Autoinstall vs Manual Installed .... differences between v156 and v156
    Hello, I just did an autoinstall of zen cart v156a and I see a feature that I do no have in the manually installed version of v156a that I am running. In the template area of the autoinstall there is a button that allows you to "Create a new template/language association" any idea why I am not seeing this button on my manual install?
    Dec 2009
    Amersfoort, The Netherlands
    Default Re: Autoinstall vs Manual Installed .... differences between v156 and v156
    The button should be there.
    What are you seeing on the template_select.php page? If you are seeing only part of the page, then perhaps there is some sort of error that needs to be corrected because of seeing a partial blank page: http://www.zen-cart.com/content.php?124-blank-page
    Otherwise, you may be seeing that a define is missing if you see this text: IMAGE_NEW_TEMPLATE
    Jun 2007
    Thank you for the replies.... I took a look again and I do see that button on both. I have so many things going on ... I may have looked at my current unupgraded store when I thought I was looking at the upgraded one.... but button is there on both. Sorry!
  1. v155 when will there be an update to v156?
    By bscho in forum General Questions
    Last Post: 18 Jan 2019, 03:11 PM
  2. v155 When will v156 work correctly?
    Last Post: 7 Jan 2019, 12:51 PM
  3. Replies: 3
    Last Post: 29 Dec 2018, 02:15 AM
  4. v155 Can I get v156 and need help with sql?
    Last Post: 25 Dec 2018, 07:54 PM
  5. v156 can not add product to shopping cart.
    By davewest in forum General Questions
    Last Post: 24 Jul 2018, 10:31 PM
