Results 11 to 20 of 27
    Default Re: Problem of checking out the cart; PHP error: 1264: Out of range value for column
    Quote Originally Posted by jfigure.com View Post
    Thank you for your modification for includes/modules/payment/paypalwpp.php regarding the table, "exchange_rate". ...
    No problem. You can change your database (make a backup first!) to change the number of characters allowed in the paypal::payment_type field by copying and pasting the following SQL query into your store's admin's Tools->Install SQL Patches:
    ALTER TABLE paypal MODIFY payment_type varchar(64) NOT NULL default '';
    That will extend the length of that field from a maximum of 40 characters to a maximum of 64, so that your store can continue to take orders. Note that the "official" Zen Cart change might be different!
    May 2013
    Tokyo, Japan
    Dear lat9,
    Thank you for remedies.
    I ran the SQL patches and confirmed that the length of the field, "payment_type" has been extended to 64. (screenshot attached)
    However, I see the field, "exchange_rate" remain decimal(4,2) despite the change of the paypalwpp.php. Do I have to care for it or don't have to because the value is set "float" anyway?
    One more question. Do I have to delete from configure.php files the following lines which @swguy suggested after implementing two changes you suggested or leave as they are?
    define('DB_MYSQL_MODE', 'NO_ENGINE_SUBSTITUTION');
    Name:  2019-05-01 6.13.32.jpg
    Feb 2006
    Tampa Bay, Florida
    Remember that there's logic in tableCheckup() that resets the length of the field payment_type - you will need to remove that.
    May 2013
    Tokyo, Japan
    Sorry to keep bothering you, guys, but I still have an error for 'exchange_rate".
    [01-May-2019 19:52:48 Asia/Tokyo] Request URI: /index.php?main_page=checkout_process, IP address: ##########
    #1 trigger_error() called at [/home/##########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php:171]
    #2 queryFactory->show_error() called at [/home/##########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php:143]
    #3 queryFactory->set_error() called at [/home/##########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php:270]
    #4 queryFactory->Execute() called at [/home/##########/jfigure-com/public_html/includes/functions/functions_general.php:952]
    #5 zen_db_perform() called at [/home/##########/jfigure-com/public_html/includes/modules/payment/paypalwpp.php:546]
    #6 paypalwpp->after_process() called at [/home/##########/jfigure-com/public_html/includes/classes/payment.php:253]
    #7 payment->after_process() called at [/home/##########/jfigure-com/public_html/includes/modules/pages/checkout_process/header_php.php:17]
    #8 require(/home/##########/jfigure-com/public_html/includes/modules/pages/checkout_process/header_php.php) called at [/home/##########/jfigure-com/public_html/index.php:36]
    --> PHP Fatal error: 1264:Out of range value for column 'exchange_rate' at row 1 :: INSERT INTO paypal (order_id, txn_type, module_name, module_mode, reason_code, payment_type, payment_status, pending_reason, invoice, first_name, last_name, payer_business_name, address_name, address_street, address_city, address_state, address_zip, address_country, address_status, payer_email, payer_id, payer_status, payment_date, business, receiver_email, receiver_id, txn_id, parent_txn_id, num_cart_items, mc_gross, mc_fee, mc_currency, settle_amount, settle_currency, exchange_rate, notify_version, verify_sign, date_added, memo) VALUES ('2517', 'cart', 'paypalwpp', 'PayPal', 'None', 'PayPal Express Checkout (instant)', 'Completed', 'None', 'EC-##########', '##########', '##########', '', '########## ##########', '##########', '##########', '##########', '##########', '', 'Confirmed', '##########', '##########', 'verified', '2019-05-01 10:52:47', '', '##########', '', '##########', '', '1', '##########', '##########', 'JPY', '0', 'JPY', '119.34816139488', '0', '', now(), '{Record generated by payment module}') ==> (as called by) /home/##########/jfigure-com/public_html/includes/functions/functions_general.php on line 952 <== in /home/##########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php on line 171.
    The change in paypalwpp.php doesn't work? How can I disable tableCheckup() that reset the length of the fields?
    Feb 2006
    Tampa Bay, Florida
    Put a return statement at the top of the function.
    Is the issue corrected if you change line 539 of /includes/modules/payment/paypalwpp.php to the following?
     'exchange_rate' => (urldecode($this->responsedata['PAYMENTINFO_0_EXCHANGERATE']) > 0 ? round((float)urldecode($this->responsedata['PAYMENTINFO_0_EXCHANGERATE']), 2) : 1.0),
  7. #17
    May 2013
    Tokyo, Japan
    Thanks. I change the paypalwpp.php file as you suggested and see what will happen. (I'm on the live site.)
  8. #18
    May 2013
    Tokyo, Japan
    Strange. The value thrown into the column, "exchange_rate", seems to have been fixed ("119.42") but I still got an error.
    [04-May-2019 01:01:38 Asia/Tokyo] Request URI: /index.php?main_page=checkout_process, IP address: ###########
    #1 trigger_error() called at [/home/###########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php:171]
    #2 queryFactory->show_error() called at [/home/###########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php:143]
    #3 queryFactory->set_error() called at [/home/###########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php:270]
    #4 queryFactory->Execute() called at [/home/###########/jfigure-com/public_html/includes/functions/functions_general.php:952]
    #5 zen_db_perform() called at [/home/###########/jfigure-com/public_html/includes/modules/payment/paypalwpp.php:546]
    #6 paypalwpp->after_process() called at [/home/###########/jfigure-com/public_html/includes/classes/payment.php:253]
    #7 payment->after_process() called at [/home/###########/jfigure-com/public_html/includes/modules/pages/checkout_process/header_php.php:17]
    #8 require(/home/###########/jfigure-com/public_html/includes/modules/pages/checkout_process/header_php.php) called at [/home/###########/jfigure-com/public_html/index.php:36]
    --> PHP Fatal error: 1264:Out of range value for column 'exchange_rate' at row 1 :: INSERT INTO paypal (order_id, txn_type, module_name, module_mode, reason_code, payment_type, payment_status, pending_reason, invoice, first_name, last_name, payer_business_name, address_name, address_street, address_city, address_state, address_zip, address_country, address_status, payer_email, payer_id, payer_status, payment_date, business, receiver_email, receiver_id, txn_id, parent_txn_id, num_cart_items, mc_gross, mc_fee, mc_currency, settle_amount, settle_currency, exchange_rate, notify_version, verify_sign, date_added, memo) VALUES ('2524', 'cart', 'paypalwpp', 'PayPal', 'None', 'PayPal Express Checkout (instant)', 'Completed', 'None', 'EC-###########', ###########', '###########', '', '########### ###########', '###########', '###########', '###########', '###########', '', 'Confirmed', '###########', '###########', 'verified', '2019-05-03 16:01:18', '', '###########', '', '###########, '', '1', '16795', '729', 'JPY', '0', 'JPY', '119.42', '0', '', now(), '{Record generated by payment module}') ==> (as called by) /home/###########/jfigure-com/public_html/includes/functions/functions_general.php on line 952 <== in /home/###########/jfigure-com/public_html/includes/classes/db/mysql/query_factory.php on line 171.
  9. #19
    From what I found in research of this issue was that in mysql 5.7 (your current version), supposedly the parentheses that follow the size definition actually do play a factor in why this error is being generated. The description found in the mysql manual indicates that for the data type of decimal having (4, 2) is that the number can only be between -99.99 and 99.99. That in this case to have 119.42, the numbers should be 5, 2 at least.
    If you rerun the alter table sql previously provided changing 4,2 to 5,2, does the error stop being generated?
  10. #20
    Nice one, @mc12345678! Do you think that, perhaps, that field should be changed from a decimal format to simply float, given the "variety" of exchange rates?
  1. 1264 Out of range value for column 'products_id' at row 1 - after importing products
    By suntower in forum Setting Up Categories, Products, Attributes
    Last Post: 20 Nov 2010, 12:23 AM
  2. 1264 Out of range value adjusted for column '2co_order_id' at row 1
    By tweakservers in forum Addon Payment Modules
    Last Post: 15 Sep 2008, 05:59 PM
  3. ERROR 1264 Out of range value
    By sharemind in forum Installing on a Windows Server
    Last Post: 25 May 2006, 02:17 AM
