Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Default Re: Problem of checking out the cart; PHP error: 1264: Out of range value for column
    Nice one, @mc12345678! Do you think that, perhaps, that field should be changed from a decimal format to simply float, given the "variety" of exchange rates?
    That's a little hard to say at the moment without further review considering the precision/rounding issues with float. It seems primarily that if decimal is used that a sufficiently large bound be placed to handle the largest possible/expected conversion rate or a method to expand it if the need arises. It certainly is worth looking into if the change to 5,2 is successful.
  2. #22
    Noting that chopping the number of significant digits to 2 will also produce rounding issues.
  3. #23
    If I remember correctly from looking over the exchange rate code set, the chopping occurs before storage and the database just sustains that cut-off number accurately. :)
  4. #24
    That's not my point ... did you look at the number of significant digits in that exchange rate (119.34816139488) identified in post #14? While that value's not (currently) used for calculations, I was thinking that the more accurate a value stored, the better.
  5. #25
    I *do* agree that accuracy in such a number (exchange_rate) should be maintained to support its financial impact.
  6. #26
    May 2013
    Tokyo, Japan
    Guys, I changed the data-type of "exchnage_rate" from decimal(4,2) to decimal(5,2). I will come back to you with the results of impact on my next order.
    I do not receive any more error for the "payment_type" since its data-type was changed to varchar(64). Thank you, lat9.
    Name:  2019-05-05 5.01.33.jpg
  7. #27
    May 2013
    Tokyo, Japan
    Dear zen-experts,
    Now everything seems alright!!!
    I received 3 orders since I changed the data-types of "payment_type" and "exchange_rate" and it seems that the customer could check out without a problem.
    I really want to say THANK YOU for all of them who help me out this.
    Best regards,
    JFigure
  1. 1264 Out of range value for column 'products_id' at row 1 - after importing products
    By suntower in forum Setting Up Categories, Products, Attributes
    Last Post: 20 Nov 2010, 12:23 AM
  2. 1264 Out of range value adjusted for column '2co_order_id' at row 1
    By tweakservers in forum Addon Payment Modules
    Last Post: 15 Sep 2008, 05:59 PM
  3. ERROR 1264 Out of range value
    By sharemind in forum Installing on a Windows Server
    Last Post: 25 May 2006, 02:17 AM
