Results 11 to 20 of 22
    Default Re: Running CEON URI Mapping in a subfolder
    OK here's the fix:
    - in includes/configure.php, use DIR_WS_CATALOG for the folder name. Don't append the folder name to HTTP_SERVER.
    - in .htaccess, you want these changes vs what's recommended in admin:
    # At the top:
    Options +FollowSymLinks -MultiViews
    DirectoryIndex index.php
    RewriteEngine On
    RewriteBase /mysite/
    # At the bottom:
    RewriteCond %{REQUEST_FILENAME} !-d
    RewriteCond %{REQUEST_FILENAME} !-f
    RewriteRule ^(.+) index.php [QSA,L]
    PLUS you need MC's suggestion about prepending /yourstore to the uris in the table ceon_uri_mappings
    I agree with everything except the "necessity" of the revised htaccess to check for the presence file and folder requests.
    When HTTP_SERVER contains, as it should, just the server and DIR_WS_CATALOG contains the sub-directory as also is expected I have had success with the provided htaccess in a sub-directory provided that sub-directory didn't also have an htaccess file. If it did, I had to reiterate the rules in that sub-directory based on the server's configuration.
    The recommended file/folder check adds additional processing to the process of searching the filesystem as compared to evaluating the provided uri to eliminate those things that are of known concern. Yes, the above recommended revision is more flexible in that the htaccess need not be revisited for future modifications, but at a page-by-page cost and allowance of alternate content to be stored in the file system matching an existing request that would otherwise be handled by index.php.
    Feb 2006
    Tampa Bay, Florida
    Quote Originally Posted by torvista View Post
    And, the table `ceon_uri_mappings` uses the subdirectory as part of the path, so you would need to regenerate the urls if the additional shop is not in the same-named directory (on a dev server) as the production site.
    Wasn't there going to be a mod that did the regeneration? I can't recall what exactly happened with this.
    I thought I saw something recently that the commercial mod that supports generation/regeneration of uris was again available at ceon.net.
    I also have something that couples with EP4 to do a sort of intermediate rewrite.
    Feb 2006
    Tampa Bay, Florida
    There you go. I knew they were working on it for a long time but it kept getting delayed and I lost track.
    For those looking for details:
    https://ceon.net/seo-modules/ceon-uri-mapping-manager
    Feb 2006
    Tampa Bay, Florida
    Oddly enough too, Ceon's own site has the "lingering zenid" problem that is one of the issues with this mod.
    Feb 2006
    Tampa Bay, Florida
    I was hoping to avoid changing the ceon_uri_mappings by programatically injecting '/mysite' as a prefix for uri during the query in getURIMappingsResultset() but no joy. Has anyone done this? I was thinking
        if (is_array($columns_to_retrieve)) {
           for ($i = 0; $i < sizeof($columns_to_retrieve); $i++) {
             if ($columns_to_retrieve[$i] == "uri") {
                $columns_to_retrieve[$i] = "concat('/mysite',uri) as uri";
          if ($columns_to_retrieve == "uri") {
            $columns_to_retrieve = "concat('/mysite',uri) as uri";
  7. #17
    I don't know what their configuration is, but I found that php version played a significant factor and it had nothing to do with the mod's presence nor absence. It just wouldn't go away properly...
  8. #18
    I haven't tried it, but I think that's only half of the solution... remember to get the data associated with a uri, the database has to be searched on the uri...
    If perhaps you tried to reach a destination using your edit and the native uri, perhaps it would come back as expected, but that's a separate search... and even then, would you want to prepend the attempted search with the sub-folder a second time if the existing uri already had that sub-folder?
  9. #19
    Feb 2006
    Tampa Bay, Florida
    LOL yes you're right. Here's the rest:
        // Remove from selections
        foreach ($selections as $key => &$sel_value) {
             if ($key == "uri") {
                $sel_value = str_replace("/yourstore", '', $sel_value);
  10. #20
    Feb 2006
    Tampa Bay, Florida
    OK all in one place for those who wish to copy & paste:
    below the global $db in getURIMappingsResultset() in includes/classes/class.CeonURIMappingDBLookup.php add:
        if (DIR_WS_CATALOG != "/") {
           // Add prefix to data
           $prefix = DIR_WS_CATALOG;
           $prefix = rtrim($prefix, '/');
                   $columns_to_retrieve[$i] = "concat('" . $prefix . "',uri) as uri";
               $columns_to_retrieve = "concat('" . $prefix . "',uri) as uri";
                   $sel_value = str_replace($prefix, '', $sel_value);
  1. v156 Ceon URI Mapping V5.0
    By Neil Kerr_Ceon in forum All Other Contributions/Addons
    Last Post: 4 Apr 2024, 12:01 AM
  2. Ceon URI Mapping v4.x
    By conor in forum All Other Contributions/Addons
    Last Post: 7 Oct 2020, 03:13 AM
  3. v139d Ceon uri mapping, how to generate uri mapping for bulk bulk-imported products?
    By mybiz9999 in forum All Other Contributions/Addons
    Last Post: 8 Jan 2013, 06:52 AM
  4. CEON URI Mapping
    By jmkent in forum All Other Contributions/Addons
    Last Post: 22 Nov 2012, 04:28 PM
  5. Ceon URI Mapping v4
    Last Post: 14 Aug 2011, 02:51 PM
