Results 1 to 7 of 7
    Jan 2009
    Iowa, USA
    Default Problem defining Breadcrumbs
    I'm using v1.5.6b, classic responsive template. The breadcrumb looks kind of goofy, so tried changing it back to what the Admin screen says is the default value ' :: '
    When I do, it automatically converts it into this which is quite unexpected
    Was actually trying for " > " as a Breadcrumb, just thought I would start with something that was documented as working. What is the workaround for this, entering the value directly into the SQL Table?
    Default Re: Problem defining Breadcrumbs
    Pretty much at this point
    Running a sql query through tools->install sql patches is an easy way to go. There has been some work done to address this more on a case-by-case basis, but it looks like a more robust fix will be in ZC 1.5.7 and maybe in 1.5.6 if there is another release of it.
    UPDATE configuration SET configuration_value = ' :: ' WHERE configuration_key = 'BREAD_CRUMBS_SEPARATOR';
    Jan 2009
    Iowa, USA
    Thanks so much for the quick response.
    Jan 2009
    Iowa, USA
    I updated the value directly from the Control Panel to '&nbsp;&gt;&nbsp;' (' > ') - worked perfectly.
    Sep 2008
    Calgary, AB
    FWIW, I went through phpMyAdmin, found Bread Crumbs Navigation Separator in the Navigation table and edited the value there. (Zen-Cart v1.5.6c on a Windows XAMPP setup.)
    Used &nbsp;&gt; to get a [non-breaking space]>
    My Sewing Room
    #148, 8228 Macleod Tr SE, Calgary, AB T2H 2B8
    mysewingroom.ca
    This worked for me using the configuration table row 400, but I used: &nbsp;&gt;&nbsp;
    I'm having a problem with Step 3 of 3 regardless of the separator. No problem with Step 1 or 2 and Step 3 works for FREE download items, but when I enter items with a price, all the html code and tags are exposed like this:
    {"breadCrumbHtml":" Home<\/a> > \n Home and Garden<\/a> > \n Checkout<\/a> > \nConfirmation\n","confirmationHtml":"
    \n\n
    Step 3 of 3 - Order Confirmation<\/h1>\n\n\n
    \n
    Billing\/Payment Information<\/h2>\n
    Edit <\/span><\/a><\/div>\n\n
    etc............................................
    Anyone know how to fix it? Is this is a header file somewhere?
    FYI I'm also using version v1.5.6c on a Windows server. Connecting to PayPal ok as my processor. No errors in logs when all the html exposed, but can't execute transaction since no button to complete purchase is available.
  1. v156 Editing Breadcrumbs layout problem
    By RixStix in forum Upgrading to 1.5.x
    Last Post: 9 Jan 2019, 11:30 PM
  2. Breadcrumbs and Categories Problem- flyout menus
    By lloyd_borrett in forum All Other Contributions/Addons
    Last Post: 2 Jan 2009, 11:11 PM
  3. defining constants
    By jumpy in forum Templates, Stylesheets, Page Layout
    Last Post: 31 Oct 2008, 07:57 PM
  4. Product page breadcrumbs problem... on PHP5 with SEO urls
    By turtledove53 in forum All Other Contributions/Addons
    Last Post: 24 Apr 2008, 02:46 PM
