Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
    Default Re: Smart Characters And Timeouts
    Check the site's /logs directory; there's a myDEBUG-*.log file that identifies what the issue is.
    Jan 2011
    [26-Jul-2019 19:12:04 America/Chicago] Request URI: /studio/admin-1538838053/index.php, IP address: 97.103.136.248
    #1 trigger_error() called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/includes/classes/db/mysql/query_factory.php:171]
    #2 queryFactory->show_error() called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/includes/classes/db/mysql/query_factory.php:143]
    #3 queryFactory->set_error() called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/includes/classes/db/mysql/query_factory.php:270]
    #4 queryFactory->Execute() called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/admin-1538838053/includes/classes/AdminNotifications.php:153]
    #5 AdminNotifications->pruneSavedState() called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/admin-1538838053/includes/classes/AdminNotifications.php:34]
    #6 AdminNotifications->getNotifications() called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/admin-1538838053/index_dashboard.php:14]
    #7 require(/home2/boruma/public_html/earcandyaudiobooks.com/studio/admin-1538838053/index_dashboard.php) called at [/home2/boruma/public_html/earcandyaudiobooks.com/studio/admin-1538838053/index.php:26]
    --> PHP Fatal error: 1146:Table 'boruma_zncr6.zc_admin_notifications' doesn't exist :: DELETE FROM zc_admin_notifications WHERE notification_key NOT IN ('square3v156') ==> (as called by) /home2/boruma/public_html/earcandyaudiobooks.com/studio/admin-1538838053/includes/classes/AdminNotifications.php on line 153 <== in /home2/boruma/public_html/earcandyaudiobooks.com/studio/includes/classes/db/mysql/query_factory.php on line 171.
    Sorry, but I have absolutely no idea what to do with all that.
    It "sounds like" you've specified (in your admin/storefront configure.php files) a DB_PREFIX of 'zc_' where the original store used a DB_PREFIX of ''.
    Be sure to rename your admin directory name, since it's been posted as part of that log's information.
    Jan 2011
    I haven't touched anything in the configure.php file. I touch the php files as little as possible because I never have understood php, and I never will.
    Under admin-1538838053, there are only three directories: backups, images, and includes. And no configure.php file. Where's the file I need to modify? Under includes? I'm just trying to clarify because I don't want to screw this up even more than the upgrade process already did.
    Check both the /admin/includes/configure.php and the /includes/configure.php to make sure that the DB_PREFIX constant is set to ''.
    Jan 2011
    The good news is, I was able to find and modify both of those files. The bad news is, I keep getting an error when I try to upload the /includes file.
    CuteFTP (or maybe the server) won't allow me to upload it. I was able to upload the admin-1538838053/includes/ file, though.
  7. #17
    Jan 2011
    The CHMOD on /includes/ is 755. Do I need to change that...and then change it back?
  8. #18
    Apr 2006
    West Salem, IL
    What is the chmod on includes/configure.php ? Probably set to 0444, change it to 0644 and upload over it then change back to 0444
    Mike
    GeekHost - Zen Cart Certified & PCI Compliant Hosting
  9. #19
    Jan 2011
    Okay, I did that and uploaded the file, then changed it back. Thanks for that.
    Now I'm getting this error message: ERROR 0071: There appears to be a problem with the database. Maintenance is required.
    And the log file says:
  10. #20
    Nope, that's the same log that you posted earlier. The message you're receiving indicates that the database credentials are not correct.
  1. v139g Any Templates for Smart Phones and Tablets?
    By irishshopper in forum Addon Templates
    Last Post: 20 Mar 2013, 12:36 AM
  2. blank page/connection timeouts
    By JaysShop in forum General Questions
    Last Post: 3 Mar 2011, 09:41 PM
  3. Ajax requests and session timeouts
    By lumpylumpy in forum All Other Contributions/Addons
    Last Post: 24 Dec 2010, 02:23 PM
  4. CyberSource TimeOuts on checkout
    By icecold in forum Addon Payment Modules
    Last Post: 17 Mar 2009, 07:16 AM
  5. Session Timeouts !!
    By Scrat in forum General Questions
    Last Post: 7 Apr 2007, 08:41 PM
