Results 1 to 8 of 8
    Feb 2007
    Pennsylvania
    Default Custom Header Links Problem (Mobile)
    Hope someone has some advice. I have a client using version 1.5.4 of Zen Cart. An upgrade is going to be done soon but we have a slight issue in the meantime. The header has custom links on the right side. They are not working in mobile. They have worked when I looked on my phone (Iphone X Max) but it is random. Other people using various phones cannot get those links it brings you back to the the main page. Any ideas what the issue may be. http://theblingthing.com
    Default Re: Custom Header Links Problem (Mobile)
    Something in your template's handling of those right-side "map" elements is setting the href in those links to all point to the site's base. If you've got a /common/tpl_header_mobile.php (or something similar) that's where I'd start looking.
    Feb 2007
    Pennsylvania
    Thanks. I will check that tonight.
    Feb 2007
    Pennsylvania
    So there apparently is no mobile template. The links are in the html_header.php in common under the template.
    This is what is in there:
    <!--Header Link Begins-->
    <map name="header-link">
    <area shape="rect" coords="754,55,1000,93" href="index.php?main_page=page&id=9" target="_blank" alt="upcoming events">
    <area shape="rect" coords="754,140,998,179" href="index.php?main_page=page&id=2" alt="Join Our Mailing List">
    <area shape="rect" coords="755,183,995,222" href="http://blog.TheBlingThing.com" alt="Visit Our Blog">
    <area shape="rect" coords="756,97,871,136" href="shopping-cart" alt="Shopping Cart">
    <area shape="rect" coords="877,97,998,136" href="my-account" alt="Your account information">
    <area shape="rect" coords="246,4,717,216" href="index.php" alt="home page" />
    </map>
    <!--Header Link End-->
    So it looks like there is really no setup for mobile itself on those header links
    That's weird, perhaps some javascript and/or jQuery getting in the middle? When I view the link you provided using FireFox's responsive viewer/mobile mode, I see that all those links have been converted back to the site's main page.
    Feb 2007
    Pennsylvania
    Yup. Will dig a bit deeper and see what I can find.
    Feb 2007
    Pennsylvania
    Strangely enough it seems to be a mobile size issue. If you change mobile view to anything higher then a phone (ie; tablet) it shows the links.
    Jan 2019
    New Zealand
    Hi ravynw,
    You have mapped your image with area coordinates which works great on desktop. But for mobile viewing you have reduced the image map size, yet have not changed the area coordinates to match the new map size.
    Regards raptar
    By austy25 in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Jan 2009, 08:09 PM
  2. Change Links in Custom Logo/Header?
    By SweetwaterLane in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Sep 2008, 09:23 PM
  3. HEADER PROBLEM! custom horizontal navigation bar
    By aruleal in forum Templates, Stylesheets, Page Layout
    Last Post: 28 Jul 2008, 07:31 AM
  4. Adding custom header links
    By chuender in forum Templates, Stylesheets, Page Layout
    Last Post: 16 Jan 2007, 10:59 PM
