Results 1 to 5 of 5
    May 2008
    UK
    Default Help required for creating a search by sizes..
    hi there
    i need some help please.
    I have set up a shop selling shoes.
    How can i have it where there is a box or part of the site where the customer can choose his or her size and then the results are displayed to cater for the search?
    Any help would be appreciated
    [Note: remember to include site URL, ZC version, list of plugins, PHP version, etc ... read the Posting Tips shown above for information to include in your post here. And, remove this comment before actually posting!]
    Dec 2009
    Amersfoort, The Netherlands
    Default Re: Help required for creating a search by sizes..
    You could use the Dynamic Attribute Filter addon
    N of San Antonio TX
    156c method USING Multiple Categories Link Manager
    1. Assume Category Men's Shoes
    2. Make Category Men's Size ## for every Men's size that you carry
    3. Go to an existing shoe
    4. Click on Copy (Blue-circled C at right of product)
    5. Click on Multiple Categories Link Manager
    6. Product's Master Category is displayed
    7. Click on all applicable sizes for the particular product
    8. Click Update Category Links
    9. Repeat with next product
    156c method NOT USING Multiple Categories Link Manager
    2. Make Category Men's Size 14
    3. Go to an existing shoe that has size 14 available
    5. Under Categories, select Men's Size 14
    6. Copy Method is Link
    7. Copy Product Attributes is N/A as this is a Link
    8. Click Copy
    You can see that, initially, using the Multiple Categories Link will get you set up faster. Single links can be done as items are added.
    Whether you consider it a viable feature or not, attributes always go with a link. So, even if customers go to a 14, they can still order a 15 (if available) of the item.
    I would consider this a feature if a particular shoe needs to be a half-size larger due to the toe of the shoe.
    User clicks on 14, description mentions to order a half-size larger, customer selects 14.5 and adds to cart.
    May 2008
    UK
    Thank you for the fast information. much appreciated.
    I am just checking if this will work on my version on zencart - i use 1.5.6c?
    Quote Originally Posted by amebb View Post
    Which? The software recommended by Design75 or the process (though not sure directly related to the request) identified by dbltoe. If to what dbltoe suggested, I would expect that based on his writeup the answer is yes, related to the software identified by Design75, I would suspect it would, but as always suggest testing on a test installation so as not to affect the live site...
  1. Need help creating a page for Wholesale?
    By cchan in forum General Questions
    Last Post: 13 Jan 2011, 10:49 PM
  2. Help required for total newbie
    By pringle in forum Basic Configuration
    Last Post: 10 Aug 2010, 04:53 PM
  3. Search for Products/Sizes from Sidebox???
    By rubbermike in forum Basic Configuration
    Last Post: 6 Nov 2009, 04:42 AM
  4. Creating Required Information
    By masantner in forum General Questions
    Last Post: 13 Jul 2009, 09:14 PM
  5. Urgent Help Needed to provide Quantity Discount for Photo Print Sizes!
    By Jules4Love in forum Discounts/Coupons, Gift Certificates, Newsletters, Ads
    Last Post: 23 Aug 2007, 05:59 PM
