Both config files should be ok but, I do get the above greeting.
* @package Configuration Settings circa 1.5.0
* File Built by zc_install on 2012-08-16 03:15:28
define('HTTP_SERVER', 'https://venla.fi');
define('HTTPS_SERVER', 'https://venla.fi');
define('HTTP_CATALOG_SERVER', HTTP_SERVER);
define('HTTPS_CATALOG_SERVER', HTTPS_SERVER);
define('ENABLE_SSL', 'true');
define('DIR_WS_PHPBB', '/');
define('DIR_FS_CATALOG', '/home/wwkupklr/public_html/');
define('DB_TYPE', 'mysql'); // always 'mysql'
define('DB_PREFIX', ''); // prefix for database table names -- preferred to be left empty
define('DB_CHARSET', 'utf8mb4'); // 'utf8mb4' or older 'utf8' / 'latin1' are most common
define('DB_SERVER', 'localhost'); // address of your db server
define('DB_SERVER_USERNAME', 'wwkupklr_venla');
define('DB_SERVER_PASSWORD', '(redacted)');
define('DB_DATABASE', 'wwkupklr_venla');
define('DIR_FS_SQL_CACHE', '/home/wwkupklr/public_html/cache');
// EOF
/*************** NOTE: This file is similar, but DIFFERENT from the "store" version of configure.php. ***********/
* WE RECOMMEND THAT YOU USE SSL PROTECTION FOR YOUR ENTIRE ADMIN:
* To do that, make sure you use a "https:" URL for BOTH the HTTP_SERVER and HTTPS_SERVER entries:
// secure webserver for admin? Valid choices are 'true' or 'false' (including quotes).
// secure webserver for storefront? Valid choices are 'true' or 'false' (including quotes).
$t1 = parse_url(HTTP_SERVER);$p1 = $t1['path'];$t2 = parse_url(HTTPS_SERVER);$p2 = $t2['path'];
define('DIR_WS_ADMIN', preg_replace('#^' . str_replace('-', '\-', $p1) . '#', '', dirname($_SERVER['SCRIPT_NAME'])) . '/');
define('DIR_WS_HTTPS_ADMIN', preg_replace('#^' . str_replace('-', '\-', $p2) . '#', '', dirname($_SERVER['SCRIPT_NAME'])) . '/');
define('DIR_FS_ADMIN', realpath(dirname(__FILE__) . '/../') . '/');
// Main webserver: eg-http://www.your_domain.com -
// HTTP_CATALOG_SERVER is your Main webserver: eg-http://www.your_domain.com
// HTTPS_CATALOG_SERVER is your Secure webserver: eg-https://www.your_domain.com
// EOF
