marcopolo
Running a fundraiser and would like to display total funds collected. We will be selling a product for example $22 dollars which $12 dollars of the sale will be donated. I created a side banner with our goal amount we are trying to achieve but will need to populate the amount collect for it to display the graph.
So for reference the product id is 1200, I will need to retrieve total sales based on a certain date range for that product id and minus $10 for each qty unit sold then out out that to a number.
Have no idea how to write that piece of code correctly, if anyone can help I would great appreciate it. Thanks in advance for any help!
Total funds collected = quantity of products_id sold within a date range * (cost of products_id in the then current currency - 10 (in applicable current currency)) displayed in the current currency.
Quantity of products_id sold:
$start_datetime = '2020-03-20 05:00:00";
$end_datetime = date(DATE_TIME_FORMAT, time()); // Is an example of checking up until now although that portion could be left off if a running total was wanted and just need to return all values greater than the start date. Else, put in the end date as desired.
$quantity_sold_query = "SELECT op.products_quantity, op.products_price, op.products_tax, op.final_price, o.currency, o.currency_value FROM " . TABLE_ORDERS_PRODUCTS . " op, " . TABLE_ORDERS . " o WHERE op.products_id = :products_id: AND op.orders_id = o.orders_id AND o.date_purchased > STR_TO_DATE(:start_datetime:, :datetimeformat:) AND o.date_purchased < STR_TO_DATE(:end_datetime:, :datetimeformat:) ORDER BY o.date_purchased ASC";
// ORDER BY ASC provides list with oldest purchase (by date) at the top and newest at the bottom.
$quantity_sold_query = $db->bindVars($quantity_sold_query, ":products_id:", 1200, 'integer');
$quantity_sold_query = $db->bindVars($quantity_sold_query, ":start_datetime:", $start_datetime, 'string');
$quantity_sold_query = $db->bindVars($quantity_sold_query, ":end_datetime:", $end_datetime, 'string');
$quantity_sold_query = $db->bindVars($quantity_sold_query, ":datetimeformat:", DATE_TIME_FORMAT, 'string');
$quantity_sold = $db->Execute($quantity_sold_query);
//Since ZC version is not identified, a generic loop is offered instead of the options available as of ZC 1.5.5 where one can
// loop on foreach instead of while (!$quantity_sold->EOF)
$money = 0;
$subtract_amount = 10;
while (!quantity_sold->EOF) {
$amount_sale = $currencies->value($quantity_sold->fields['final_price'] * $quantity_sold->fields['products_quantity'], true, $quantity_sold->fields['currency'], $quantity_sold->fields['currency_value']);
$amount_deducted = $subtract_amount * $quantity_sold->fields['products_quantity'];
$amount_sale -= $currencies->value($amount_deducted, true, DEFAULT_CURRENCY);
// If item was free or some other characteristic caused it to be free, then do not remove more from the funds collected.
if ($amount_sale < 0) {
$amount_sale = 0;
$money += $amount_sale;
echo $currencies->format($money);
Ok, so the above is untested and is using code that looks like it is compatible with Zen Cart 1.5.6. I have not gone back to validate when fields such as o.currency and o.currency_value began being stored to possibly support the above conversions and I'm not even sure if multiple currencies are an issue, but I wanted to try to provide as complete of a solution as I could...
Really, there may be errors including issues with currency conversion and for those I apologize, check your logs folder after trying to incorporate the above wherever it is to be added and has been viewed. Also pull out your calculator if multiple currencies are involved. I really have not given this the thought it may need to ensure that the calculations come out correctly, but I had seen this posted a while ago and wanted to at least offer some assistance.
I haven't really looked to see what type of currency data/relationship is stored to ensure that the code is properly converting from whatever is stored to what is being displayed... It may differ between ZC versions as well, but the above should provide an idea of an approach that would be expected.
I tried to also make it PHP 7.x compliant (non-complaining) by ensuring all variables were declared to an appropriate datatype/value before use.
