Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    Feb 2009
    atlanta GA
    Default EZPages not showing in mobile using responsive classic template
    Important links is not showing up in a new install from 1.5.5f to 1.5.6c. I am using a test domain to make sure everything works right. I install a fresh copy of 1.5.6c to ( http://www.salvagecrate.com). Without touching anything , important links show in mobile. As soon as I import my tables from the 1.5.5f install , important links looks like this
    What am i doing wrong ? This problem has had me stumped for many days.
    Zencart 1.5.6c PHP 7.2 Order Replacement AC Adapters and Power Cords Online www.missingcord.com
    Feb 2006
    Tampa Bay, Florida
    Default Re: EZPages not showing in mobile using responsive classic template
    In 1.5.6c, the template file
    includes/templates/responsive_classic/templates/tpl_modules_mobile_menu.php
    pulls in ezpages_bar_header.php
    So you want to look at
    includes/modules/ezpages_bar_header.php
    (or the overridden file if you have changed it - includes/modules/responsive_classic/ezpages_bar_header.php
    What you see in this file is that a select is done with a WHERE clause including
    AND e.status_header = 1
    AND e.header_sort_order > 0
    You are showing them in your sidebox. So you want to change this to
    AND e.status_sidebox = 1
    AND e.sidebox_sort_order > 0
    In the default file this would be on line 25
    Unfortunately, ZC 1.5.6 (including sub-versions a-c) was distributed with an ezpages html "section" that was smaller than its predecessors. There is a fix associated with 1.5.6 (included in 1.5.7) for if there is a 1.5.6d version released. The difference(s) can be seen in comparing:
    1.5.6c:
    https://github.com/zencart/zencart/b...t_156.sql#L187
    Available for next 1.5.6:
    Basically the field is "truncated" from a mediumtext field length to a text field length.
    The above is the difference in the upgrade path, but a fresh install using either of those two branches has the same sized field.
    Another reason the field can go blank is when having a mix of collations where one or more "special" characters are used and the entire field goes blank. But I suspect from the upgrade path of above and associated issue that the above is the cause.
    A couple of follow on questions to ensure we are all on the same page.
    Seeing as the OP here was carried over from another thread, once the database was imported, it was upgraded using the zc_install upgrade process, correct?
    The discussion of this being a "mobile" issue, are you simply referring to the hamburger dropdown or any display of the ezpage content? Ie. Is the content still present in the admin area or has it disappeared from there as well?
    What has been the method of identifying that it is a mobile only issue? Is it not also on the desktop? Not just talking theory, but trying to rope it in.
    Have you tried copying and pasting the content from 1.5.5 to the 1.5.6c admin area or generated new content just to further identify if the above truncation of field is an issue/source?
    Feb 2006
    Tampa Bay, Florida
    @MC he's not having trouble displaying an EZPage, he's having trouble with the menu that provides links to EZPages.
    Feb 2009
    atlanta GA
    No change after editing that file
    Feb 2009
    atlanta GA
    1.5.6c:
    The ezpages show on the desktop version. As swguy said , they just won't show on the menu that provides them in mobile. Yes we upgraded the database with zc_install. Yes the hamburger dropdown. I can visit any of the expages manually. It just won't show them in that drop down with the links. Well they show in desktop and everywhere else in the sidebox just fine.
    Feb 2006
    Tampa Bay, Florida
    Just looked at your site again - the EZ pages are not showing up in the Important Links sidebox either.
    Please check Admin > Tools > EZ-Pages and verify that for (pick one EZPage) you have:
    - Sidebox radio button set to Yes
    - Sidebox sort order set to > 0
    Feb 2009
    atlanta GA
    kk checking now. I did a full refresh again because I knew you guys where helping me. I wanted to remove anything I may have done wrong in my attempt to fix it.
    Update i just realize i need to update the database again since i refreshed. Also the expages show at least when i view it in browser for desktop. Click image for larger version.
    Quote Originally Posted by jasonshanks View Post
    Does your template directory have an override for that file and has the same modification as suggested been made to it?
    Of course, I say that but this is supposedly a new software install without any other mods....
    Feb 2009
    atlanta GA
    database patch complete. @swguy , here is my Ez-page admin section. Click image for larger version.
ID:	18929 . @mc12345678 , I have made no changes. I just imported the tables and database patched. Mmmm my template folder on the 1.5.5f site is called responsive_classic_v1 , is this the cause ? Would that carry over with the table import ?
  1. v155 Method to show only subcategories in mobile menu Responsive Classic Stock 1.55f
    By twitchtoo in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Oct 2020, 08:40 PM
  2. v156 How to Enable Mobile Menu (Jquery mmenu) on Desktop Layout of Responsive Classic?
    By RobertH in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Jun 2019, 03:45 PM
  3. v155 ? on Customizing Responsive-Classic template v1.5.5f
    By byakudan in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Oct 2018, 10:34 AM
  4. v155 Classic Responsive Template - file permissions
    By karine in forum Templates, Stylesheets, Page Layout
    Last Post: 25 Jun 2018, 03:54 PM
  5. v155 Recommended Image Sizes using Responsive Classic?
    By Zean in forum Basic Configuration
    Last Post: 18 May 2016, 01:56 PM
