Hi, using V1.5.6c Anyone know where to turn on reviews? It is listed on the site but the user cannot leave a review? https//www.medical4usa.com
Thank you,
Flguy
Thank you,
Flguy
Go to the product page and click Write Review.
@Flguy
checking out your site i believe if you change the logo to view centered looks more appeasing to the eye ...
includes/templates/responsive_classic/css/stylesheet.css
add this:
#logo{text-align:center;}
Mark
Hare Do
I thank you for sending me the info and I did that I opened it and it is showing On but you go to the site and open it and the Cursor will not work?
https://www.medical4usa.com If you have a minute please take a look at it
Thank you,
The site has no reviews that I see.
Cannot create review without being logged in (that's good)
Perhaps provide a dummy account for testing.
- your create account page crashes, so you'll want to fix that.
otherwise, write a review worked. I would recommend a lower minimum than 50 characters but it's up to you.
You have a review in your pending queue that you probably want to delete.
I thank you for the help so maybe take it to "0"?
Hi, I don't understand what you are saying I am not a computer guy my web designer made the site. So, please tell me what should have them change?
Thank you,
Flguy
He is saying that it looks like you have it set to 50 characters for a review. He is saying that you should bring that down, you can do this in your admin panel Configuration ... Minimum Values look for the reviews and bring that down. I believe 50 is default.
Jonathan
We Rock Hostng LLC
