Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Jun 2020
    KLIN
    Default Re: Catalog/product Listing Page Not working properly
    The debug logs show these now:
    [17-Jun-2020 16:54:25 UTC] Request URI: /admin/categories.php?cPath=, IP address: IP ADDRESS
    #1 sizeof() called at [/home/domain/public_html/admin/includes/modules/category_product_listing.php:405]
    #2 require(/home/domain/public_html/admin/includes/modules/category_product_listing.php) called at [/home/domain/public_html/admin/categories.php:669]
    [17-Jun-2020 16:54:25 UTC] PHP Warning: sizeof(): Parameter must be an array or an object that implements Countable in /home/domain/public_html/admin/includes/modules/category_product_listing.php on line 405
    #1 sizeof() called at [/home/domain/public_html/admin/includes/modules/category_product_listing.php:422]
    [17-Jun-2020 16:54:25 UTC] PHP Warning: sizeof(): Parameter must be an array or an object that implements Countable in /home/domain/public_html/admin/includes/modules/category_product_listing.php on line 422
    [17-Jun-2020 16:54:18 UTC] Request URI: /admin/category_product_listing.php, IP address: IP ADDRESS
    #1 sizeof() called at [/home/domain/public_html/admin/category_product_listing.php:1150]
    [17-Jun-2020 16:54:18 UTC] PHP Warning: sizeof(): Parameter must be an array or an object that implements Countable in /home/domain/public_html/admin/category_product_listing.php on line 1150
    #1 sizeof() called at [/home/domain/public_html/admin/category_product_listing.php:1166]
    [17-Jun-2020 16:54:18 UTC] PHP Warning: sizeof(): Parameter must be an array or an object that implements Countable in /home/domain/public_html/admin/category_product_listing.php on line 1166
    Nov 2005
    los angeles
    i would suggest you closely review how you did your upgrade; and perhaps try again. your upgrade looks like you missed a few things.
    Quote Originally Posted by rndm1 View Post
    categories.php in v156c is 531 lines. hard to get an error on line 669.
    categories.php in v155 is 1013 lines.
    author of square Webpay. called the savior by the chief bottle washer...
    available for hire.
    Jun 2020
    KLIN
    Yes. I have upgraded the install again and it fixed most of the issues, thank you for the help.
    Is it possible to edit the text highlighted in red in the attached image?Name:  imageedit_3_5865763391.jpg
    The image is from when trying to checkout.
    While I have a "suspicion" of where that text is located, now is a good time to learn how to use the tools->developers toolkit to find content in files so that you can find the file(s) you want to edit.
    Once in the developers toolkit, if you go to the lower left corner and type in a portion of the text sought, say: PLEASE BE AWARE THAT
    And then select catalog from the dropdown menu and check the box related to matching case and press the search button, you should be presented with the file(s) that contain that text. Then, keeping the template override system in mind, you will want to edit the file that has your current template in its path... if no such folder is identified in the path, then it would appear that a base file has been edited and it probably should be copied over to your template folder's location within the path.
    If the filename begins with define_
    Then there is the define pages editor where the content can be edited, but it should still be placed in the template override "first".
    Jun 2020
    KLIN
    got it, thanks a bunch.
  1. v154 Product Listing Image not displaying properly in Chrome
    By charmlt in forum Templates, Stylesheets, Page Layout
    Last Post: 25 Mar 2015, 07:08 PM
  2. v151 Featured Products below product listing not working properly
    By Shara in forum Setting Up Categories, Products, Attributes
    Last Post: 26 Oct 2013, 02:37 PM
  3. Formating not working on product listing page
    By leest35 in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Jun 2010, 08:08 PM
  4. Admin--Index Listing is not working properly
    By thegolfguru in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Oct 2009, 06:45 AM
