    Oct 2012
    St. Catharines, ON Canada
    Default I need help with the basics
    I'm back to using Zen-Cart 1.5.6c and am starting from scratch.
    I want to make the common changes like the Welcome Guest and the Congratulations modifications but as I read it's recommended to use Google to search for help, the help I found in doing so did not give me the result I'm looking for.
    I'm wondering if it's to do with the new template as I'm not using the Contemporary Green one.
    I would guess there is an area here that would give me the help I need in getting rid of the Welcome Guest and Congratulations messages but I also want to change the logo at the top of the main page etc.
    I did try to search on the site here but as it stated, it's useless.
    Can someone please point me in the right direction again? I used Zen-Cart before but that was many years ago and only the green template was being used.
    Thank you in advance.
    My site is at https://afghansniagara.ca
    Feb 2006
    Tampa Bay, Florida
    Default Re: I need help with the basics
    If it isn't found there, then the FAQs area of this forum site which does actually have a decent search feature/result works.
    Keep in mind as items are desired to be changed to think about/consider the template override system. Doesn't seem like a big deal or of concern now, but it makes a difference when going for the upgrade.
    Oct 2012
    It turns out those are the pages I had printed and the directions didn't work for me.
    Nov 2005
    los angeles
    Quote Originally Posted by rensing View Post
    i would encourage you to be more specific with regards to what you did and what did not work.
    there was a lot of work done to make the new the latest ZC documentation accurate and user friendly. if it is incorrect, then i'm sure someone would want to change so that it is accurate.
    what did you try and what happened?
    best.
    author of square Webpay.
    Oct 2012
    Since i removed 156 and did a fresh install of 157 I moved my issue to a more appropriate forum since it was no longer a upgrade related issue.
    Thanks for your help.
  1. Need help with stylesheet - Need to delete the categories
    By annav in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Jun 2009, 12:41 PM
  2. Help with Meta Tags - Basics
    By TheEggman in forum General Questions
    Last Post: 13 Jul 2008, 10:37 AM
  3. I need help with the Susbscription Manager
    By LaughterStore in forum Managing Customers and Orders
    Last Post: 4 Apr 2007, 11:23 PM
  4. Need Help with a couple of issues with the shop
    By chrisb in forum Templates, Stylesheets, Page Layout
    Last Post: 3 Oct 2006, 12:36 PM
  5. Need help with coding - can't find the file were the error is coming from
    By cowlickdesign in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Aug 2006, 04:11 PM
