Salemaker does not understand linked products
https://www.proteawines.jp/shop/
ZC 1.5.6c
PHP 7.3.15
Hi all,
I noticed that Salemaker, which is so convenient to handle categories, does not work for me when a category consists of products copied (as linked products) from other categories.
Case in point: I have 5 wineries, each with red, white, and rose wines. Each winery is a category.
I have made separate categories for red, white, and rose wines, copying as links the relevant products from the winery categories.
Now, if I want to have a sale on rose wines, I set Salemaker with just the rose category checked, with no result at all. There is no error log to be found.
If however I check also one of the winery categories for the sale, then the corresponding product(s) in the rose category show a discount.
I assume this is a known issue, with linked products, and wonder if this is fixed in 1.5.7, or whether I need to change the procedure for creating new categories from existing ones. I want to avoid duplicating products if possible though.
Zen Cart 1.5.6c modified to support Japanese language (postage module support work in progress). Upgraded incrementally each version from initial 1.5.5d.
