Thank you very much for your reply.
So, I took most recent v1.5.5e tpl_footer.php from /includes/templates/template_default/common/
and added most recent Integration code from JROX: https://jam.jrox.com/kb/article/91/c...th-zencart.php
After debugging I do not have any log file generated in /public_html/logs/ folder.
However, result is the same -> blank page.
New tpl_footer.php (2016) is here:
* Common Template - tpl_footer.php
* this file can be copied to /templates/your_template_dir/pagename<br />
* example: to override the privacy page<br />
* make a directory /templates/my_template/privacy<br />
* copy /templates/templates_defaults/common/tpl_footer.php to /templates/my_template/privacy/tpl_footer.php<br />
* to override the global settings and turn off the footer un-comment the following line:<br />
* <br />
* $flag_disable_footer = true;<br />
* @package templateSystem
* @version $Id: Author: DrByte Fri Jan 8 17:06:29 2016 -0500 Modified in v1.5.5 $
require(DIR_WS_MODULES . zen_get_module_directory('footer.php'));
if (!isset($flag_disable_footer) || !$flag_disable_footer) {
<!--bof-navigation display -->
<div id="navSuppWrapper">
<div id="navSupp">
<ul>
<li><?php echo '<a href="' . HTTP_SERVER . DIR_WS_CATALOG . '">'; ?><?php echo HEADER_TITLE_CATALOG; ?></a></li>
<?php if (EZPAGES_STATUS_FOOTER == '1' or (EZPAGES_STATUS_FOOTER == '2' and (strstr(EXCLUDE_ADMIN_IP_FOR_MAINTENANCE, $_SERVER['REMOTE_ADDR'])))) { ?>
<li><?php require($template->get_template_dir('tpl_ezpages_bar_footer.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_ezpages_bar_footer.php'); ?></li>
<?php } ?>
</ul>
<!--eof-navigation display -->
<!--bof-ip address display -->
if (SHOW_FOOTER_IP == '1') {
<div id="siteinfoIP"><?php echo TEXT_YOUR_IP_ADDRESS . ' ' . $_SERVER['REMOTE_ADDR']; ?></div>
<!--eof-ip address display -->
<!--bof-banner #5 display -->
if (SHOW_BANNERS_GROUP_SET5 != '' && $banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET5)) {
<div id="bannerFive" class="banners"><?php echo zen_display_banner('static', $banner); ?></div>
<!--eof-banner #5 display -->
<!--bof- site copyright display -->
<div id="siteinfoLegal" class="legalCopyright"><?php echo FOOTER_TEXT_BODY; ?></div>
<!--eof- site copyright display -->
} // flag_disable_footer
<?php if (false || (isset($showValidatorLink) && $showValidatorLink == true)) { ?>
<a href="https://validator.w3.org/check?uri=<?php echo urlencode('http' . ($request_type == 'SSL' ? 's' : '') . '://' . $_SERVER['SERVER_NAME'] . $_SERVER['REQUEST_URI'] . (strstr($_SERVER['REQUEST_URI'], '?') ? '&' : '?') . zen_session_name() . '=' . zen_session_id()); ?>" target="_blank">VALIDATOR</a>
## START JAM INTEGRATION WITH ZEN CART ##
## ZC Integration code by DrByte 8/2006 ##
if ((int)$orders_id > 0) {
$JAM = $db->Execute("select class, value from " . TABLE_ORDERS_TOTAL . " where orders_id = '".(int)$orders_id."' AND class in ('ot_coupon', 'ot_subtotal', 'ot_group_pricing')");
while (!$JAM->EOF) {
switch ($JAM->fields['class']) {
case 'ot_subtotal':
$order_subtotal = $JAM->fields['value'];
case 'ot_coupon':
$coupon_amount = $JAM->fields['value'];
case 'ot_group_pricing':
$group_pricing_amount = $JAM->fields['value'];
$JAM->MoveNext();
$commissionable_order = ($order_subtotal - $coupon_amount - $group_pricing_amount);
$commissionable_order = number_format($commissionable_order,2,'.','');
echo "<script language=\"JavaScript\" type=\"text/javascript\" src=\"https://www.idtagsonline.com/affiliates/sale.php?amount=$commissionable_order&trans_id=$orders_id\"></script>";
## END JAM INTEGRATION WITH ZEN CART ##
