Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Jan 2015
    Default Re: Installer Problem with Upgrade button
    GoldBuckle, did you get your upgrade to work? I'm looking at multiple sets of instructions and can't get it working. I can do clean install which blows away the old database, but can't get the install to work with old files mixed in.
    Dec 2006
    near Atlanta Georgia
    Yes, see the instructions below regarding bringing in an older data base.
    John
    Jan 2015
    where below?
    I've got this many to date:
    implementation guide
    https://docs.zen-cart.com/user/upgra...led_upgrading/
    https://www.zen-cart.com/entry.php?3...he-new-version
    https://docs.zen-cart.com/user/first...t-using-cpanel
    https://docs.zen-cart.com/user/upgra...orary-database
    https://docs.zen-cart.com/user/upgra..._only_upgrade/
    Just got it to upgrade: put 1.57 files in folder, added 2 old configure files and the upgrade button appeared.
    Dec 2006
    Until this last post, the OP (original post'er) has never given any indication of doing step 4. And, even with all matching DB info, you will not get an upgrade button until zc_install sees an earlier version in the DB tables. Thus my
    You will not get an upgrade button on any new install. The upgrade option in zc_install is only available IF/AFTER you have brought in an older database backup.
    John
  1. Replies: 1
    Last Post: 15 Jan 2018, 12:41 AM
  2. v155 upgrading 1.55a to 1.55b (locally): installer does not offer upgrade
    By torvista in forum Upgrading to 1.5.x
    Last Post: 8 Nov 2016, 07:58 PM
  3. v153 [Done v1.6.0] Installer database upgrade db-error fails
    By Jarkko in forum Bug Reports
    Last Post: 12 Feb 2015, 09:00 PM
  4. Replies: 2
    Last Post: 28 Mar 2013, 10:56 PM
  5. Changed button images - problem with search button
    By DVDTitan in forum Templates, Stylesheets, Page Layout
    Last Post: 18 May 2007, 04:58 PM
