Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Apr 2009
    Default Re: Browsing all products per category
    I have used much the same code. But have put it in its own template/module and then included it in tpl_index_categories.php.
    The reason for that is that most people seem to want to keep the subcategory links as well, which I think might get lost in the method DrByte mentioned. So, putting it all in its own file allows it to be slotted in wherever people want.
    7
    Quote Originally Posted by niccol View Post
    Indeed.
    And v157 has some notifier hooks built-in which make some of these code changes even simpler to extract out to separate code. And the index_filters were restructured to be simpler to customize.
    Oct 2019
    UK
    Thanks all - Mum is now critically ill so will go over this fully when we know the outcome
    Jan 2022
    UK
    Thanks for this going way back. Are you able please to supply an update as I am now on v1.57.
    Thanks in advance
    Jan 2022
    UK
    Thanks I'll give that a try. Basically I just want to reproduce what Amazon does when you select a genre
    Feb 2006
    Tampa Bay, Florida
    I have a plugin that I'll release soon called "View All" which removes pagination from a product listing page and shows all the entries. Not sure if this is what you want.
  1. Not all products are listed in category 'all products'
    By jcdk in forum Basic Configuration
    Last Post: 15 Feb 2010, 09:07 AM
  2. Strange sub category problem while browsing products
    By canemasters in forum General Questions
    Last Post: 31 Aug 2009, 06:54 AM
  3. Products All Listing - How to have 'X' products shown per row
    By tqualizer in forum Templates, Stylesheets, Page Layout
    Last Post: 31 Jan 2008, 05:28 AM
  4. Coding advice... show Subcategories' products when browsing main category?
    By bodyjewelrystores in forum Setting Up Categories, Products, Attributes
    Last Post: 25 Dec 2007, 05:35 PM
  5. All products in a category on the screen while browsing.
    By PaulineNMU in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Jul 2006, 04:04 AM
