    Apr 2011
    Espoo, Finland
    Default zen_get_products_quantity_min_units_display
    lines535...549 of includes/functions/function_prices.php:
        // quantity max
        $check_max = zen_get_products_quantity_order_max($product_id);
        if ($check_max != 0) {
          $the_min_units .= '<span class="qmax">';
          if ($include_break == true) {
            $the_min_units .= ($the_min_units != '' ? '<br />' : '') . PRODUCTS_QUANTITY_MAX_TEXT_LISTING . '&nbsp;' . $check_max;
            $the_min_units .= ($the_min_units != '' ? '&nbsp;&nbsp;' : '') . PRODUCTS_QUANTITY_MAX_TEXT_LISTING . '&nbsp;' . $check_max;
          $the_min_units .= '</span>';
        return $the_min_units;
    AS '<span class="qmax">' string is being added (assigned) to $the_min_units variable, there is no sence to check if it is empty later.
    My suggestion:
        // quantity max
            $the_min_units .= ($the_min_units != '' ? '<br />' : '') . '<span class="qmax">' . PRODUCTS_QUANTITY_MAX_TEXT_LISTING . '&nbsp;' . $check_max;
            $the_min_units .= ($the_min_units != '' ? '&nbsp;&nbsp;' : '') . '<span class="qmax">' . PRODUCTS_QUANTITY_MAX_TEXT_LISTING . '&nbsp;' . $check_max;
    Default Re: zen_get_products_quantity_min_units_display
    Nevermind, found the code. Scuse me.. :)
    Nov 2005
    los angeles
    Quote Originally Posted by yesaul View Post
    valid point.
    i would suggest having code discussions and potentially doing a PR over on github. this section of code looks to have some changes in v158:
    https://github.com/zencart/zencart/b....php#L559-L616
    and your "bug" seems to have been addressed. please correct me if i am wrong.
    this $include_break test seems to be done a few times as well. i see other refactor potential, as in:
    $breakElement '&nbsp;&nbsp;'
    if ($include_break) {
    $breakElement '<br>';
    and then we can reduce the 3 conditionals to 1, and just include that $breakElement var as needed. which i personally thinks improves readability.
    best.
    author of square Webpay.
    When looking at the ZC 1.5.8 version of this area, I question the importance of *always* forcing the additional character(s) associated with $the_min_units and/or why the span's class must *always* encompass that information? E.g. why not place the span information after the additional assignment of $the_min_units instead of incorporating the span into the following text.
    Instead of:
        if ($check_max > 0) {
                $the_min_units .= ($the_min_units != '' ? '<br>' : '');
                $the_min_units .= ($the_min_units != '' ? '&nbsp;&nbsp;' : '');
            $the_min_units .= PRODUCTS_QUANTITY_MAX_TEXT_LISTING . '&nbsp;' . $check_max;
    Making it:
    Or if incorporating the above "breakElement":
            $the_min_units .= ($the_min_units != '' ? $breakElement : '');
    If the "span" does need to fit around the break (assuming a break like character is needed because of earlier text), then would suggest generating an additional variable to support the check being able to omit inserting the break element when it is "currently" not required:
            $span_max_class = '<span class="qmax">';
            $the_min_units .= $span_max_class;
            $the_min_units .= ($the_min_units != $span_max_class ? $breakElement : '');
    This is suggested because there are those that don't want a break forced for an empty set of previous text either for html validation or look and to not require some sort of additional CSS, javascript/jQuery, or other code to "remove".
  1. How Do I Make This Alteration To zen_get_products_quantity_min_units_display... ?
    By coffee granules in forum Setting Up Categories, Products, Attributes
    Last Post: 12 Nov 2008, 11:55 PM
