Results 21 to 30 of 32
  1. #21
    Jun 2007
    Eustis, Florida, USA, EARTH
    Default Re: Missing footer and header classic responsive android
    Understanding how Google crawls is important. They don't see the page the way you do, they are looking at the raw HTML, and being that the mobile menu is in the HTML, hidden from view until someone taps the hamburger menu to slide it in, it is indexable. Just because it is hidden from the viewer until clicked doesn't mean it is hidden from the crawler.
    You don't suppose spiders read the meta tags from the source too do you? LOL
    ZC v1.5.7 "I was so much older then...I'm younger than that now" Cut the umbilical cord with webhosts after 20 years. FREEDOM!
  2. #22
    Apr 2006
    West Salem, IL
    how about the "customer thinks the guy who designed the website is an idiot" rule when they follow a long-established UX pattern that clicking the logo takes you to the home page and they click the logo and immediately they are kicked to the dialer unexpectantly? Bad user experience can push a customer away
    Mike
    GeekHost - Zen Cart Certified & PCI Compliant Hosting
  3. #23
    Jun 2007
    FYI: the only urls in the source code that I could find were the urls from header footer and horizontal cat tabs.
  4. #24
    Jun 2007
    Quote Originally Posted by barco57 View Post
    Are you missing the redundant HOME icon text at the top left on your websites? It's easy to miss, since its the very first word on the website. I have it on all of mine, like every other standard website.
  5. #25
    Apr 2006
    West Salem, IL
    sigh, you need to learn how to use the tools.
    The first item after the body open tag in MOBILE VIEW is the following which is the mobile menu
    <nav id="menu" class="mm-menu mm-vertical mm-theme-dark mm-effect-listitems-slide mm-offcanvas mm-iconpanel"><div class="mm-panels mm-vertical"><div class="mm-panel mm-vertical mm-opened mm-current mm-iconpanel-0" id="mm-0"><a href="#mm-0" class="mm-subblocker"></a><ul class="mm-listview mm-vertical">
        <li><a href="https://lakecountyprocessservers.com/">Home</a></li>
        <li><a href="https://lakecountyprocessservers.com/index.php?main_page=contact_us">Contact Us</a></li>
        <li><a href="https://lakecountyprocessservers.com/index.php?main_page=login">Log In</a></li>
        <li class="mm-vertical"><em class="mm-counter">8</em><a class="mm-next mm-fullsubopen" href="#mm-1" data-target="#mm-1"></a><span>Services</span>
    <div class="mm-panel mm-vertical" id="mm-1"><a href="#mm-1" class="mm-subblocker"></a><ul class="level2 mm-listview mm-vertical"><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=17">Astor Florida Process Server</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=18">Bank Reps</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=16">Tavares Process Server</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=6">Process Server Cities</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=7">Pick-up or Court Filing</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=8">Courier Service</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=12">Eustis Notary Public</a></li><li>
    <a href="https://lakecountyprocessservers.com/index.php?main_page=index&amp;cPath=20">Process Server Fees</a></li></ul></div>
        </li>
        <li class="mm-vertical"><em class="mm-counter">2</em><a class="mm-next mm-fullsubopen" href="#mm-2" data-target="#mm-2"></a><span>Information</span>
          <div class="mm-panel mm-vertical" id="mm-2"><a href="#mm-2" class="mm-subblocker"></a><ul class="mm-listview mm-vertical">
            <li><a href="https://lakecountyprocessservers.com/index.php?main_page=site_map">Site Map</a></li>
            <li><a href="https://lakecountyprocessservers.com/index.php?main_page=unsubscribe">Newsletter Unsubscribe</a></li>
          </ul></div>
        </li>
        <li class="mm-vertical"><em class="mm-counter">4</em><a class="mm-next mm-fullsubopen" href="#mm-3" data-target="#mm-3"></a><span>Important Links</span>
          <div class="mm-panel mm-vertical" id="mm-3"><a href="#mm-3" class="mm-subblocker"></a><ul class="mm-listview mm-vertical">
    <li><a href="https://lakecountyprocessservers.com/index.php?main_page=page&amp;id=1">Welcome</a></li>
    <li><a href="https://lakecountyprocessservers.com/index.php?main_page=page&amp;id=2">Lake County Attorneys</a></li>
    <li><a href="https://lakecountyprocessservers.com/index.php?main_page=page&amp;id=4">Orange County Attorneys</a></li>
    <li><a href="https://lakecountyprocessservers.com/index.php?main_page=page&amp;id=14">Mortgage Foreclosure Service of Process</a></li>
          </ul></div>
        </li>
        <li id="menu-search">
          <form name="quick_find_header" action="https://lakecountyprocessservers.com/index.php?main_page=advanced_search_result" method="get"><input type="hidden" name="main_page" value="advanced_search_result"><input type="hidden" name="search_in_description" value="1"><input type="text" name="keyword" size="6" maxlength="30" style="width: 100px" placeholder="Enter search keywords here" aria-label="Enter search keywords here">&nbsp;<input class="cssButton submit_button button  button_search" onmouseover="this.className='cssButtonHover  button_search button_searchHover'" onmouseout="this.className='cssButton submit_button button  button_search'" type="submit" value="Search"></form>    </li>
      </ul></div></div></nav>
    Which is hidden, by default, from view by
    .mm-menu.mm-offcanvas {
        display: none;
        position: fixed;
    clicking the hamburger menu injects classes that unhide it.
    Mike
  6. #26
    Jun 2007
    I reduced FF to minimum to get the mobile version then read the source. Couldnt find it there. But now I know. Thanks for the tip.
    I tried viewing source on android but apparently not possible.
  7. #27
    Apr 2006
    West Salem, IL
    reducing the window on the desktop when using Responsive Classic won't show you the mobile source because the browser user agent doesn't change and the classes/Mobile_detect.php doesn't see it as mobile so the mobile menu doesn't get sent to the user. When in developer mode you can set it to be a iphone, samsung, etc which will trigger the mobile_detect.php will see it as a mobile device, and then the mobile menu with be shipped to the browser. That's how sites built using the mobile_dectect script handle it, Bootstrap, on the other hand, doesn't do device detection and ships the entirety of the page to the browser which is why you can see the mobile menu in its source when on desktop view.
    Mike
  8. #28
    Jun 2007
    Im not finding that. At least not in FF. I clicked responsive mode from the FF menu and I get the android version....which doesnt even show the hamburger menu, let alone have it appear in the source code.
  9. #29
    Apr 2006
    West Salem, IL
    see firefox screenshot F12 to get into developer tools and then click on the circle icon in the image to switch to device mode and then pick your device from the top of the screen
    Mike
  10. #30
    Jun 2007
    ABP was blocking everything. go figure.
  1. Replies: 2
    Last Post: 8 Aug 2021, 11:57 PM
  2. v157 Adding a header background image to Responsive Classic template
    By GoldBuckle in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Mar 2021, 09:31 PM
  3. v155 Responsive classic emplate issues...
    By rainbow_pixie_star in forum Addon Templates
    Last Post: 4 Nov 2018, 04:02 PM
  4. v155 header image for responsive classic?
    By vvomble in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Jun 2016, 10:00 PM
  5. v155 Responsive Classic vs Responsive Sheffield Blue vs ?
    By Zean in forum Templates, Stylesheets, Page Layout
    Last Post: 13 May 2016, 07:01 AM
