Results 1 to 8 of 8
    May 2011
    Tennessee
    Default How can i limit shipper for liquid products
    I ship some products which are liquid and must be shipped UPS. How can I select UPS for liquid products?
    Feb 2006
    Tampa Bay, Florida
    Default Re: How can i limit shipper for liquid products
    Nothing is built in for this, you'll have to create some custom code.
    Apr 2009
    Have a look at l big royal mai. I added attributes to limit shipping. You could do something similar with your shipping methods.
    Mark Brittain
    buy the fantastic advanced shipper mod, it's worth it, we've been using it for years and couldn't function without it.
    Zen Cart and it's community are the best!!
    Mar 2008
    Belgium
    I have perhaps a solution. I use it for a type of "letterbox-package". I made a zones variant for it and added code to disable that module if certain categories are found in the cart.
    Since you permanently have to disable other shipping modules than UPS for it, it could work for you too. However some conditions come with this:
    • all liquids must be in a category or categories by themselves
    • you can not do it in the admin panel
    • you'll have to edit some files
    So, if you do this: backup your files first!
    Example category is 5, adjust this to your category.
    Insert following code in the modules you don't want to ship liquids in:
          // bof skip certain categories
    if (IS_ADMIN_FLAG == false && $_SESSION['cart']->in_cart_check('master_categories_id','5') > 0) {
    $this->enabled false;
    // eof skip certain categories
    in zones I placed it under:
          // disable only when entire cart is free shipping
    if (zen_get_shipping_enabled($this->code)) {
    $this->enabled = ((MODULE_SHIPPING_BRIEVENBUSPOST_STATUS == 'True') ? true false);
    If there's more than one category, repeat the code with the next category and so on. I tried using '1' || '2' || '3' instead of '5' to exclude 1, 2 and 3 but that fails to work properly.
    It has to be placed where the code is for checking if the module has to be shown.
    May 2011
    Tennessee
    Quote Originally Posted by Philibel View Post
    Good idea, I will try it even though I dont like changing code. I am surprised ZenCart has not addressed this issue. Its common knowledge that certain products must be shipped by specific shippers in the USA.
    Mar 2008
    Belgium
    I took another look at the code and for my use I needed limitations to different quantities.
    The code could cleaner for an overall limitation to zero.
    if (IS_ADMIN_FLAG == false)  {
                if (
    $_SESSION['cart']->in_cart_check('master_categories_id','5') == true) {
    Example is category 5, adjust as needed.
    I also thought you could have use for Numinix Product Fields if you add the product field "Products condition". If all liquids are therein marked as "liquid", you could use:
        // bof skip liquids
                if (
    $_SESSION['cart']->in_cart_check('products_condition','liquid') == true) {
    // eof skip liquids
    Than you don't need to enter a lot of code for every category, leave products in every category according to other criteria and still grab them all as liquids.
    Always test in a test environment or test site.
    May 2011
    Tennessee
    Which PHP file is this code supposed to be placed?
  1. v154 Maximum Postage limit for advanced Shipper Module?
    By PudzPud in forum Addon Shipping Modules
    Last Post: 15 Aug 2016, 12:56 AM
  2. v151 Ceon Advanced Shipper - how can I limit the display of available shipping methods?
    By dysfunctional in forum Addon Shipping Modules
    Last Post: 31 Jan 2015, 04:03 AM
  3. Optional Container Charges for Liquid Products Sold by the Pound
    By brewbrothers in forum Setting Up Categories, Products, Attributes
    Last Post: 9 Jul 2011, 09:37 PM
  4. Replies: 11
    Last Post: 19 Dec 2009, 06:44 PM
  5. How can i limit amount of products per buyer?
    By sagivle1 in forum Managing Customers and Orders
    Last Post: 14 Apr 2009, 04:52 PM
