Results 1 to 7 of 7
    Jan 2022
    Default Admin won't load any products
    I've done a fresh install of v1.5.7c
    I have installed a free template but the admin remains untoched and is the original. I am trying to edit a product, when I select 'Categories/Products' nothing loads, there is just a blank space aqnd ZenCart logo.
    I've looked into the categories.php in the admin/includes folder:
    $categoryId = (isset($_GET['cID']) ? (int)$_GET['cID'] : '');
    if ($categoryId != '') {
      $category = $db->Execute("SELECT c.categories_id, cd.categories_name, cd.categories_description, c.categories_image,
                                       c.sort_order, c.date_added, c.last_modified
                                FROM " . TABLE_CATEGORIES . " c, " . TABLE_CATEGORIES_DESCRIPTION . " cd
                                WHERE c.categories_id = " . $categoryId . "
                                AND c.categories_id = cd.categories_id
                                AND cd.language_id = " . (int)$_SESSION['languages_id']);
      $cInfo->updateObjectInfo($category->fields);
    Since by default the cID parameter is not passed then the select won't be executed, so I can't see how this would ever work.
    Any ideas?
    Feb 2006
    Tampa Bay, Florida
    Default Re: Admin won't load any products
    when you select Categories/Products it should load
    http://YOURSITE.com/admin/index.php?...roduct_listing
    Jan 2022
    that is the url yes- but as mentioned no content is loaded.
    I can force the content by doing this at around line 30:
    $action = (isset($_GET['action']) ? $_GET['action'] : 'update_category_meta_tags');
    I changed it from:
    $action = (isset($_GET['action']) ? $_GET['action'] : '');
    Why does the ternery function default to an empty string?
    Sounds like a partial blank screen issue which likely has generated a mydebug-adm type log file in the logs directory that should have more information about what is going on that is unless the logo described is at the bottom of the screen as in the footer area.
    Quote Originally Posted by spacebiscuit75 View Post
    I changed it from:
    Line 30? That ternary evaluation is performed at line 15 of a default install. So what modifications are incorporated to push that down an additional 15ish lines? And why does using update_category_meta_tags in admin/category_product_listing.php do anything when that term does not even exist in this file?
    When claiming a fresh install of v157c, what is the origin of the database? Is it blank, have demo product or was a database imported from some other store?
    Jan 2022
    Seems that I had installed some patched SQL from a theme which I guess has broken some config. I did a fresh install and brought eh config and admin tables over to fix it. Apologies.
    Has been a good exercise though, I got to see a little under the hood regarding config etc.
    Feb 2006
    Tampa Bay, Florida
    I look forward to future pull requests from you, grasshopper! :)
  1. Admin panel won't load in browser
    By paults in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 9 Oct 2011, 05:16 PM
  2. admin won't load please help
    By julia44 in forum General Questions
    Last Post: 27 May 2007, 06:09 AM
