Now apache service is unavailable, localhost does not display.
root@crosshair:~# systemctl status apache2.service
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2022-08-15 08:53:48 EDT; 51s ago
Docs: https://httpd.apache.org/docs/2.4/
Process: 3001 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
CPU: 20ms
Aug 15 08:53:48 crosshair systemd[1]: Starting The Apache HTTP Server...
Aug 15 08:53:48 crosshair apachectl[3004]: AH00526: Syntax error on line 13 of /etc/apache2/sites-enabled/Zentest.com.conf:
Aug 15 08:53:48 crosshair apachectl[3004]: Invalid command 'SeverAlias', perhaps misspelled or defined by a module not included in the[##############################]>[/COLOR]
Aug 15 08:53:48 crosshair apachectl[3001]: Action 'start' failed.
Aug 15 08:53:48 crosshair apachectl[3001]: The Apache error log may have more information.
Aug 15 08:53:48 crosshair systemd[1]: apache2.service: Control process exited,
Aug 15 08:53:48 crosshair systemd[1]: apache2.service: Failed with result 'exit-code'.
Aug 15 08:53:48 crosshair systemd[1]: Failed to start The Apache HTTP Server.
Typo in ServerAlias, fat fingers.
Still apacheservice does not restart.
apache2.service: Control process exited, code=exited, status=1/FAILURE
