The content described earlier is not required while using the v1.3.5 contribution
Thanks doc!
It loads very fast even w/the glut of plugins. Seems nice but...
My main interest is in getting an easy to use editor to permit my client to use STYLES with text - but the documentation at moxiecode on setting this up is a major pain to understand. As I would assume everyone wants this minimum ability could someone please spell this out.
To make this request here simpler - I need help!
How does one get this style's plugin to work. Could we even get the download to have this functioning with some styles and a simple explanation for adding styles?
I know everyone is very busy, but this seems to be the solution mod that loads fast, and adds XHTML controls in a clean fashion. If someone could stremline this it would be amazingly helpful for thousands of ZC users.
kind regards /mark
Any tricks needed to be done? What are the settings for the editor in admin?
I just downloaded the files in right folders in my server but I can't see any Tiny, tinyMCE anywhere... maybe it is too tiny.
Elli
I may be blond but at least I found Zen.
elli
go into admin > catalog > categories/products
you should see a dropdown top right. use it to select tinymce. if you don't see it there then try reinstalling the files.
there are no real settings - it seems to just be up and running.
THE BRICK WALL - IS HOW TO GET SOME STYLES IN THE DROPDOWN SELECTOR ON THE CONTROL PANEL...??
anyone.....?
It would also be nice to change the font sizes from pt values to em's or px ---------
Thnak's a lot, flambeau!
This is the only one way to solve the problem of editors!
After days of scouring html area info and getting nowhere in my efforts to make this work in my ssl spce I read flambeau - re tiny
I have now uploaded and appear to have working Tiny MCE thanks to you
I still don't know why HTMLAREA won't work but it's no longer an issue
many thanks flambeau
Val :-)
TinyMCE works just fine but uploading images still causes headache. There is all CHMods triple checked and so on but still when I try upload new image through ibrowser i get error message: "Error occurred while handling file upload. Please try again."
Has anyone faced same problem than me?
Already so thankful and sincerely Yours,
Rami
Yes, I had the same problem. I solved it changing the following folders Chmod to 777:
/admin/tiny_mce/plugins/ibrowser/temp
/admin/tiny_mce/plugins/ibrowser/scripts/phpThumb/cache
Thank for Your answer but I have changed those mode 777 as well... I'm starting to be littlebit desperate with issue... Is it possible that server causes this kind of problem?
Hi...noob zenner here!
Got this working with ezpages and products, but can't seem to get it working for define pages editor. I pasted the same code as I did with the others, can someone help?
Thx/ Doug
