// Main webserver: eg, http://localhost - should not be empty for productive servers
// HTTP_CATALOG_SERVER is your Main webserver: eg, http://www.yourdomain.com
// HTTPS_CATALOG_SERVER is your Secure webserver: eg, https://www.yourdomain.com
define('HTTP_SERVER', 'http://www.newcastleprosound.com.au');
define('HTTPS_SERVER', 'https://www.newcastleprosound.com.au');
define('HTTP_CATALOG_SERVER', 'http://www.newcastleprosound.com.au');
define('HTTPS_CATALOG_SERVER', 'https://www.newcastleprosound.com.au');
define('DIR_WS_ADMIN', '/store/admin/');
define('DIR_WS_CATALOG', '/store/');
define('DIR_WS_HTTPS_ADMIN', '/store/admin/');
define('DIR_WS_HTTPS_CATALOG', '/store/');
define('DIR_FS_ADMIN', '/s101/home4/prosound/store/admin/');
define('DIR_FS_CATALOG', '/s101/home4/prosound/store/');
define('DB_TYPE', 'mysql');
define('DB_PREFIX', 'store_');
define('DB_SERVER', 'mysql'); // eg, localhost - should not be empty
define('DB_SERVER_USERNAME', 'db');
define('DB_SERVER_PASSWORD', 'pwd');
define('DB_DATABASE', 'db');
define('STORE_SESSIONS', 'db'); // leave empty '' for default handler or set to 'db'
define('DIR_FS_SQL_CACHE', '/s101/home4/prosound/store/cache');
