Rather than fooling with permissions and guessing ...
How about delete the files that it says cannot be found and reload them from a clean copy of Zen Cart to their default permissions ...
NOTE: your shop is loading ... your admin is not ...
Download the file /admin/includes/configure.php
Rename the directory /admin to /admin_old
Now reload the /admin in entirety and then upload the /admin/includes/configure.php that you saved from your site ...
NOTE: check that this is the Admin configure.php and not an accidental copy of the Catalog configure.php
All done. Same problem
Who are you hosting with?
hosting with www.trimcomputers.com
The host is a friend of mine and has all the lates stuff running on his server
well, i also did the same. its still the same...
wat if i re-install it again? would it work?
I've tried that few times with no avail
is there any other solutions to this problem? cause it's kinda bothering me for some time now. still i cant find the reason why it won't work. Or maybe it's like u said, the hosting might not be compatible with the Zen Cart.
In that case, I'd send a support ticket to the web hosting service you're related with and ask for an inspection of your folder permissions settings. If they cannot handle it - run and ring the bell on some doors who can really host Zen Cart properly. In the mean time, you can always visit the ' certified hosting plans ' section from this site.
alias101....
You said your admin/includes/configure.php says:but your /includes/configure.php says:PHP Code:
define('HTTP_SERVER', 'http://localhost');
define('HTTPS_SERVER', 'https://127.0.0.1');
define('HTTP_CATALOG_SERVER', 'http://localhost');
define('HTTPS_CATALOG_SERVER', 'https://localhost');
define('DIR_WS_ADMIN', '/store/admin/');
define('DIR_WS_CATALOG', '/store/');
define('DIR_WS_HTTPS_ADMIN', '/store/admin/');
define('DIR_WS_HTTPS_CATALOG', '/store/');
define('DIR_FS_ADMIN', '/admin/');
define('DIR_FS_CATALOG', '/');
define('DIR_FS_SQL_CACHE', '/s101/cache');
and you're running on a live server, not a standalone test server?PHP Code:
define('HTTP_SERVER', 'http://www.costaricapharmacyonline.com');
define('HTTPS_SERVER', 'https://www.costaricapharmacyonline.com');
define('ENABLE_SSL', 'true');
define('DIR_FS_CATALOG', '/kunden/homepages/13/d161596823/htdocs/costarica/store/');
define('SQL_CACHE_METHOD', 'file');
define('DIR_FS_SQL_CACHE', '/kunden/homepages/13/d161596823/htdocs/costarica/store/cache');
Thus, your admin/includes/configure.php needs to have your real info:I would also suggest that you change your /includes/configure.php setting for this to none:PHP Code:
define('HTTP_CATALOG_SERVER', 'http://www.costaricapharmacyonline.com');
define('HTTPS_CATALOG_SERVER', 'https://www.costaricapharmacyonline.com');
define('DIR_FS_ADMIN', '/kunden/homepages/13/d161596823/htdocs/costarica/store/admin/');
