Can anyone tell me where I could find a module / sidebox for FAQ my store is running ZenCart V1.3.
All your support is appreciated.
Adam.
Adam.
Since the subject title should be about v1.3.0.1 and not v3.1, first, the latest version release is up to v1.3.0.2 of Zen-Cart. You should upgrade to the latest in order to fix encountered issues that were recently fixed.
As for the FAQs, would it be possible to elaborate the question a little bit ? Do you mean to put a sidebox link, from your site, in order to be pointed on this site or you're looking for to add your own FAQs links on your site ? (which, I believe, would make more sense this way).
Please advise.
Thanks for your reply, yes I'm looking for my own FAQ's that links to my own site.Originally Posted by TheOracle
Adam.
I remember seeing a contribution module, from the downloads section, when it used to be the old forum. A FAQ sidebox page was all pre-configured to add our own FAQs link. Now, can't seem to see it no more but you might want to take a look in there.
Not Sure...but this is what you might be looking for...
http://www.perfectdesigning.net/down...q_Manager.html
However not sure if it works with 1.3.0.2
www.planetebio.net - Eat Right Feel Good !
Ah ! marvelous - that's the one I was talking about.
Cool...
But I could not get it to work in 1.3.0.2...
If you get it to work , please let me know....
I just took a look at the readme file, from inside that package, and this is what is states as a tested compatible version:
Version: 1.0
Designed For: Zen Cart v1.2x Release
The provided URL is not supported for Zen-Cart v1.3x - period - unfortunitely.
