Page 55 of 57 FirstFirst ... 5455354555657 LastLast
Results 541 to 550 of 570
  1. #541
    Default Re: How do EZ-Pages work?
    You should then start by selecting "sidebox" and not footer for your easy pages
    layout box controller and enable the sidebox
  2. #542
    Hoedspruit
    Thanks. But why is the side box option used for the footer?
  3. #543
    Do not understand??
    There are 4 settings for a page
    header
    sidebox
    footer
    TOC
  4. #544
    Hoedspruit
    Do not understand??
    header
    sidebox
    footer
    TOC
    Coffee in hand. Good morning Kobra
    Let's work on this now - no interruptions
  5. #545
    Hoedspruit
    Do not understand??
    These have all been toggled and orders entered and removed in the past.
    header
    Status - disabled
    sidebox
    Status - enabled, sort order 25
    footer
    Status - enabled, order 30
    TOC
    Status - enabled, Chapter 1, TOC 10
    Configuration>EZ-Pages Settings
    Display status of footerbar and sidebox both 1 = on
    The footer display is my first prize position. Is there a way to incorporate the pricing and custom products links into the shop column?
  6. #546
    Hoedspruit
    I will use the header bar in the interim.
    Maybe Anne of Picaflor-Azul has a patch to incorporate EZ-Pages links into their template
  7. #547
    Jul 2009
    picaflor-azul.com
    Quote Originally Posted by Parafanaylya View Post
    No patch is needed. If you want ezpages in the header besides in the drop down menu (depending on the template used) just turn them on in zen cart admin--configuration--ez pages
    Hoedspruit
    Quote Originally Posted by picaflor-azul View Post
    The template by Picaflor-Azul is slick and clean. The EZ-Pages nav bar looks as if somebody pasted onto the page. It does not look cool.
    Attachment 15310
    I want to place the links in the footer only. The bar that appears with the header slices the template in 2, and the footer links are ugly.
    Any chances?
  9. #549
    Jul 2009
    picaflor-azul.com
    Any chances?
    What template are you using?
    Hoedspruit
    Winchester Responsive
  1. v154 Links ON ez-pages TO OTHER turned-off ez-pages don't work after upgrade
    By anduril3019 in forum Upgrading to 1.5.x
    Last Post: 19 May 2015, 09:12 AM
  2. how do i get javascript to work in the ez pages?
    By warroyo90 in forum General Questions
    Last Post: 28 Mar 2012, 05:14 AM
  3. How can I get my CSS navigation tabs to work for groups of similar pages?
    By sifuhall in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Nov 2009, 07:57 PM
  4. Replies: 3
    Last Post: 22 Jul 2008, 12:01 AM
  5. Bwahahaha How do I get ez-pages to work?
    By hodgejr in forum General Questions
    Last Post: 8 Oct 2007, 09:10 AM
