Page 57 of 57 FirstFirst ... 747555657
Results 561 to 570 of 570
  1. #561
    Nov 2004
    Default Re: How do EZ-Pages work?
    I noticed a problem with ez-pages when configured to use an internal URL. When the ez-page link is generated within the header or footer, the link is correct and shows the internal URL.
    However, if you access the ez-page directly via URL, is shows the ez-page with empty HTML content (because it is empty) and does not redirect to the internal URL.
    example:
    www.domain.com/index.php?main_page=page&id=10
    What do you think?
    Experience is what you get when you don’t get what you want…
  2. #562
    Aug 2016
    Melbourne, Australia
    Thank you for all the information here - I was able to build my first EZ page!! And it worked!
  3. #563
    Jun 2007
    Eustis, Florida, USA, EARTH
    Cant seem to find the answer to my question.
    Internal url link /index.php?main_page=index&cPath=16
    Parses html as /index.php?main_page=index&cPath=16
    which of course will not produce a page.
    ZC v1.5.4 "I was so much older then...I'm younger than that now" Cut the umbilical cord with webhosts after 20 years. FREEDOM!
  4. #564
    Feb 2006
    Tampa Bay, Florida
    You are specifying the URL incorrectly. It should be more like
    index.php?main_page=YOUR-NAME-FOR-THE-PAGE
    That Software Guy, Plugin Moderator. Store: Zen Cart Modifications
    Contributions: Quantity Discounts, Better Together, SMS on Sale, Gift Wrap at Checkout, and more.
  5. #565
    7
    Quote Originally Posted by pixelpadre View Post
    I'm guessing you've got outdated Admin sanitizer code. There were a few iterations to it between v155 to v155e.
  6. #566
    Jun 2007
    V155e.
    Fresh install.
  7. #567
    Jun 2007
    External link parses correctly.
  8. #568
    Jun 2007
    I stand corrected v155d
  9. #569
    7
    I have a fresh brand new v1.5.5e install I just set up.
    I went to admin ez-pages, and created a new page, and put in the internal link of:
    and clicked Save.
    The link works fine on storefront.
    Then went back into admin ez-pages, and clicked edit. Link appears correct. Clicked save. Saved properly, no re-encoding. Link works fine on storefront.
  10. #570
    Jun 2007
    OK, I will have to upgrade to e at some point. Thanks.
  1. v154 Links ON ez-pages TO OTHER turned-off ez-pages don't work after upgrade
    By anduril3019 in forum Upgrading to 1.5.x
    Last Post: 19 May 2015, 09:12 AM
  2. how do i get javascript to work in the ez pages?
    By warroyo90 in forum General Questions
    Last Post: 28 Mar 2012, 05:14 AM
  3. How can I get my CSS navigation tabs to work for groups of similar pages?
    By sifuhall in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Nov 2009, 07:57 PM
  4. Replies: 3
    Last Post: 22 Jul 2008, 12:01 AM
  5. Bwahahaha How do I get ez-pages to work?
    By hodgejr in forum General Questions
    Last Post: 8 Oct 2007, 09:10 AM
